Wheeler
Purchased this week. Didn't notice on the test drive (Of course), but when I started it up later that day after buying it I got met with the first error message:
"Ground Fault detected" [Reset or Close]. Reset just makes it disappear for 3 seconds and it pops up again. Close makes it go away for the remainder of the drive. I've seen videos and images of other people where they're showing something in the Pro Power screen or on the app - <200w in use or something. My pro power screen icon (where it shows available power) just shows greyed out in the truck and on the app. I hit "generator mode" and it goes green for a second, then the same message pops up and it stops working seemingly. Ground Fault again and again.
Maybe I don't understand how this is supposed to be functioning while I'm operating the vehicle, but this doesn't seem right. I took it in for service today (60 miles on the truck BTW) and was told I needed to "Set up the FordPass app to get the OTA update". The truck itself (in the truck's settings on the SYNC) is set up for those updates - when I press "update" it says it's current. The app just tells me that there's nothing recurring set up (??). I'm of course logged in, can lock/unlock the truck with the app, etc.
I've already checked the driver's side under the bed for unconnected connectors, they're hooked up. Anything else? It doesn't appear there's an OTA I can download. Should I check the engine bay fuses for the inverter?
