Hebed118
Can anyone help me understand what needs to be done differently on a 2021 to install fox coilovers? I've been told be several sources that they will not fit without modification, but I've seen several folks with them installed. So what needs to happen? I've seen that the lower perch needs to be adjusted. Is there anything else required as to why Fox will not come out and say it'll work on a 2021.
I'm looking at the 2.0 or 2.5 system. Fit-up should be the same I'd imagine between the two.
Curious to hear any thoughts you all may have. I'm not seeing many options specifically calling out a 2021.
