Spindrive
Matthew
F150
So. Marked with tape. Cut below the line with a jigsaw using a wood finish blade, then I sanded up to the tape line using a random orbital sander and 80 grit. Then finished off the edges with 220 grit and hand rounded the corners with a 220 block.
I'll try to get some better pics tomorrow. But overall I like this better. It leaves strength in the plastic under the tow hooks and has just the slightest deflection left to assist with road noise underneath.
I wonder if this would have negative impact on MPG on a already leveled truck….
M4X
M4X
2022 F150 Lariat "Sport" FX4
I think it would probably affect a truck that's not leveled more than a truck that is. But the bigger tires you'll probably put on it after you level it will affect it more.
About to go down that rabbit hole myself.
moates
Matt
2021 Space White F150 3.5 XLT FX4
FF
You removed the active air dam from this one too?
RedStorm
Gary
2021 F150 3.5L EcoBoost
How hard was it to remove the fog lights to remove the entire fixed air dam? Or did you just need to unbolt them? Also, was it necessary to pull back the fender liner?
I removed the motors and active air dam without having to remove anything else. It can all be reached from behind/underneath.
M4X
M4X
It looks so good. No increased noise that I can notice other than the rare wind buffet if you're cresting a hill and there's a strong wind blowing underneath for a moment (think 30mph headwind gust). MPG loss around town seems to be about 0.2mpg so far (most of my roads are 55mph roaads so that probably makes the worse loss than a normal speed limit town of 45mph or less). Probably 1mpg loss on highway.
Worth it for me for the look and the increased approach angle.
Ford F-150 Lightning Removed Active Air Dam From my F-150 - DIY Writeup PXL_20220217_211520345
My42waffles
Kegan
21 power boost 157, lightning reservation
Maintenance
I just want to put this info up for anyone plan to add the tremor skid plate like me. The listed part number mentioned (ml3z8419Baptm) is wrong. I ordered it and that one is the plain one that is for the normal trucks. The tremor is ml3z8419Daptm ordered from vin for tremor.
Hamlet
Kevin
Winnipeg, Canada
2021 F150 Lariat 502A Sport, 2014 Chevy Camaro SS
What size and make tires are those? I like the look and want something similar for all terrain?
M4X
M4X
Nitro Ridge Grappler 285/65R20 on factory Lariat Sport 20’s. No spacers. No rubbing, full lock (with 2” Readylift Level, but they should fit a stock suspension w/o rubbing as well)
Tires measure out essentially to 34.9/11.5 (according to NITTOs tire specs)
JerseyGlock
Jimmy
New Jersey
2021 Lariat Powerboost
Anyone in NJ, PA and NY looking to sell their 2021 removed active air dam? I'm looking to do a project on it. Please let me know, thanks.
RedStorm
Gary
I'm slightly outside your listed states(MD). But looking to get rid of mine.
