Here in Boise one of the local car stereo shops also sells and installs rear-view cameras for travel trailers. Maybe a similar shop local to you would do the install for you.I started the thread long ago (2021 F150 Plat) - and have had the part LC3Z1A189D (camera and TPMS). Find it really good to confirm that I have the right part. Really good to see that it has been successfully installed. Installation, however, is not within the range of my capabilities, so I am still looking for either a dealer or shop to do that. Any advice on that front would be appreciated.
The Yaw sensor should have come with the the Tow Technology package, which I assume you have.If I have a new December build 2022 with MAX tow package, 360 cameras, Pro trailer system….but have a 2 wire harness, shouldn’t it be on the dealer to give me the correct harness?
The available features won’t work without it.
My propane tanks are in the way to use the sticker, so I need the transmitter, and also want the TPMS. Do I need the Ford camera to utilize the full assist?
Can I have all 3?
There is a post above with the part numbers for the othear stuff. SHort answer, you can get:
* TPMS only
* Trailer Camera only
* TPMS + Trailer Camera
All say they are compatible with the Yaw sensor (the trailer cable should have the connector for the Yaw plus whatever you are adding).
From the description on the TPMS only kit, yes. It stated it was compatible with the Yaw sensor and from the picture, it looked like there were two connectors on the trailer side cable.I didn’t get the cable YAW sensor, just the sticker pack. Does the cable that connects to the bumper, on the trailer side, allow for multiple connections for each accessory?
Assuming I get the correct harness with more than 2 wires.
2022 built in Dec, KR PB 6.5', Max Tow, 360 Cam, Blue Cruise, etc.The Yaw sensor should have come with the the Tow Technology package, which I assume you have.
That makes sense to me. I'm guessing the vast majority of owners don't use even the stickers. For Ford to ship a yaw sensor with every truck would be a huge waste of money on their part.No longer include Yaw Sensor ONLY stickers. Manual says you can purchase Yaw Sensor as Accessory from Ford.
There, I fixed it for you.That makes sense to me. I'm guessing the vast majority of owners don't use even the stickers. For Ford to ship a yaw sensor with every truck would be a huge waste ofmoneychips on their part.
Chips may be their primary concern but, considering how sensitive manufacturers are to any cost at all, they'll save additional money on the rest of it. The wires and housing aren't free.There, I fixed it for you.![]()
