2022 Lightning Wheel and Tire Sizes | OEM 20” & 22”
PungoteagueDave
We need to get the message to Ford that a lot of Platinum Lightning buyers want a smaller wheel size. It looks great, bu 20's or even 18's would be far preferable given the range and ride penalties. I'm still going Platinum but will be forced aftermarket for wheels.
T i h o r
Rohit
Toronto
Self Employed
Any idea on the rim size and offsets?
Im new to Ford, but am thinking they would have kept it close to the G14 ICE F150's
Tenetke
Stuart
‘22 Lightning Platinum, ‘21 Aviator, ‘23 Bronco WT
dad
On my Expedition Platinum the offset is +44 I believe. So probably the same or similar on an F150. I have some +30 offset wheels on it now. I ordered a Platinum in the first wave and will be getting a new set of wheels because I don’t like the wheels on the Platinum. More than likely I get new tires, some like Michelin LTX and some Nitto Terra Grappler G2’s.
TF1000
Ted
Wisconsin
2018 Prius Prime, 1996 Ram 1500
Conflicting how. Typically a less stiff tire will decrease rolling resistance due to the tire construction.
I guess I was thinking more about tire pressure. Hyper-milers like to increase tire pressure to the max which decreases rolling resistance but gives a harsher ride. Also the low rolling resistance tires we have gotten for our Prius's are not known for their comfortable ride.
ryan
Ryan
Midwest
sedan
I cannot buy the Lightning Platinum because of its low profile 22 inch wheels/tires. I have to drop to the 20 inch Lariat (18 inch would be better).
What concerns me more is the All-Terrain (A/T) versus All-Season options. I want the best traction with my 1/2 mile dirt driveway in snow but that is about the limit of my off-road use.
I would rather have less noise, better pavement traction, higher MPGe, and a softer ride when most of my driving occurs. Currently the Lightning standard will be A/T, despite the photo above.
One projection I saw was a $150 option to switch from A/T to A/S tires on the Lariat.
I agree with you on preferred tire size but any tire shop will sell you a set of basic 18s whether you buy a plat or lariat.
BEMOH
Stopasking87#
Toyota Sienna, Prius PHEV, F150 Lightning
I'm on a mission as I hit 40 to have ridiculous wheels on all our vehicles (annoys the wife and I think it looks hilarious). I'm thinking gold, 6 spoke, with grabbers? Shouldn't hurt the range too much....
Ford F-150 Lightning 2022 Lightning Wheel and Tire Sizes | OEM 20” & 22” truck
VTbuckeye
Vermont
Will 17 inch wheels fit? I will probably get 17s or 18s with winter tires, but I need to know what fits and actually have the truck first. With regards to the bright wheels. I like them. I also would consider getting two of one wheel and two of another (same width offset...) so as to have one color/pattern on one side and one on the other. Nobody would see both at the same time.
BEMOH
Stopasking87#
No clue if 17s fit, just used a 2022 F150 for mock up. Tirerack has zero specs on wheel size for the Lightning.
T i h o r
Rohit
Toronto
Self Employed
I bumped another thread just a moment ago, but I believe this is actually a better thread to get the updated information on the oem offsets. Also, do we know the centre bore? I'm assuming it's the same as ICE F150's?
Hopefully someone can chime in soon. Hoping to order some new rims before the truck arrives!
VictorM
Victor
Western PA
F150 Lightning XLT ER
Experiential Knowledge Griot
I think they’re the Dynapro AT2. They’re a decent AT tire but may be geared more toward highway use with some off road capability. I wish they went KO2
My plan is to switch from the Dynapro AT2 to the Continental TerrainContact A/T. I have a small tire shop nearby that will swap the whole set upon arrival.
Can someone tell me if I can place a larger tire on the 20” OEM rims?
