PLEASE HELP: Bambi Mode Backfired for me in FORScan
Knickell
Kyle
Mazda Protege, Ford F-150
Hey guys, I need to call on you for some help. I tried to enable "Bambi" mode on my F-150, and now my fog lights will not come on at all. The LED signature lighting works, but the full fog light will not.
Does anybody know the original code for the regular mode, so I can start new again?
I saved a profile before getting started. How do I reload that profile to the truck, or fix the fog lights to where they come back on with the proper coding? Has anyone else experienced this issue, and what was you fix?
I'm a little worried right now, so any help/fixes are truly appreciated.
Knickell
Knickell
Kyle
@Livnitup , maybe you have some insight? I know you complied the spreadsheet, I hope you can help me out!
iceman77
Pete
2022 Ford F-150 Platinum
If you saved the BCM configuration before changing anything in ForScan, you can restore it easily. Just enter programming configuration for BCM, press "Load All" (at the bottom of your screen), browse for the saved configuration file, click Open then press "Write All". That should do it!
Knickell
Knickell
Kyle
I saved the OEM profile. I just could not figure out how to reload it. Is that what you're referring to?
I will have to try that later when I get home.
iceman77
Pete
Yes
Knickell
Knickell
Kyle
That did not work so far. Do you happen to have the correct code to get the fog lights to come back on?
This is what I’m currently working with:
Ford F-150 Lightning PLEASE HELP: Bambi Mode Backfired for me in FORScan 4AFC392B-6AFD-45E2-A513-0F9A259014B7
The code I found on the spreadsheet does not work for me.
Ebrou
Mobile, AL
2021 F150 XLT SCREW 5.0L Sport 4x4
This is mine which is from a XLT 302A. Not sure which package you have.
726-39-01000100000068
726-39-02 0101 0000 006A
Bocephus
Bocephus
MI
2021 F150 XLT 302A 3.3L
Entertainer
726-39-0201010000006A
Correct 726-39-02 above is the same as mine. Did you get it to work properly?
