Blue Cruise Not allowing hands free
eefiv1
Ed
Indiana
2022 F-150 Lariat PowerBoost (On Order)
I just can't see to get the handsfee to work.
Thanks to all the folks on the ECR module progamming guide thread (https://www.f150gen14.com/forum/threads/ecu-module-programming-guide-using-fdrs.8249/unread) I was able to easily upgrade by Job 1 2021 F150 without much issue. Everything seems fine. Under Sync/About it shows the Handsfree valid through 10/2022. I even get prompts on the dash that Blue Cruise is available, however it never allows the handsfree option. It still requires my hands on the wheel. It does however monitor whether or not I am watching the road and warns when I do not.
At first I thought maybe for some reason the section of I65 I drive everyday was not on the approved Blue Cruise roads, but I did a trip on I64 today as well, with the same results. I have no errors, all the appropriate settings are enabled in Sync. All of the updates are applied with no issues. I have even reset Sync and FP just to rule everything out.
Any thoughts on what I might be missing?
Ajzride
Alan
Houston
Eng
Well, just save everyone asking to verify settings, maybe post pictures of all your sync settings and about screen.
eefiv1
eefiv1
Ed
Indiana
Good idea. Here you go.
Ford F-150 Lightning Blue Cruise Not allowing hands free 20220327_200415
Ford F-150 Lightning Blue Cruise Not allowing hands free 20220327_200422
Ford F-150 Lightning Blue Cruise Not allowing hands free 20220327_200456
Ford F-150 Lightning Blue Cruise Not allowing hands free 20220327_200504
Ajzride
Alan
Houston
Eng
That all looks good. It would be a pain in the butt to set everything back up, but I might try a reset on the APIM.
eefiv1
eefiv1
Ed
Indiana
Is that done through Forscan? Or something done in FDRS?
eefiv1
eefiv1
Ed
Indiana
OK. Gotcha. I didn't know if it was something more involved. I'll give it a go in the Am. Thanks.
Jesse-Infotainment
2021 F150
Looks like you aren’t truly active?
the date should be a year from when it was activated that date is a place holder? I may be wrong I don’t have BC but isn’t it suppose to update to march date?
Ajzride
Alan
Houston
Eng
I did forget to ask if you got your activation email from Ford.
eefiv1
eefiv1
Ed
Indiana
I didn't get an email, but I got the notice in Fordpass.
Orlando150
Orlando, FL
Ford
You have lane centering on in the settings but have you tried activating it with the button on the wheel?
Jesse-Infotainment
2021 F150
Log in on your computer to FordPass and manage connected services see what it says in there
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Mine is exactly like his. It was in the app as one year when app notified me. No emails. . But obviously it didn't communicate that from there to the truck. Did a master reset, didn't help. Resetting the apim and tcu sent an array of probs. My connected services showed my original 3 year Nav sync pending and it wanted the $600 to activate BC. The one year disappeared. FP reps got my 3 year Nav sub back, but BC is also gone from Connected Services.
eefiv1
eefiv1
Ed
Indiana
Before I performed the Master Reset this morning only Connected Navigation showed up under Connected Services. I performed the Master Reset as recommended and the truck has not yet given me the Ford Pass Activation message and now shows pending on the FP App. I will go out to the truck a little later and see if it has the prompt to activate yet.
