Adding Forward Sensing System - 2021 King Ranch w/601A
antho
Anthony
Houston, Texas
2021 801A Raptor
@Omodan, did the harness that you bought have the two extra sensor connectors for the outside corners of the bumpers (that you didn't use)? Just curious as I am guessing part # LU5Z15K859ABPTM is for those two, and part of the auto-parking system. Thx for any info.
Yeah, The outer 2 sensors are for the active park assist, There are also 2 on the rear sides.
Omodan
Randal
Augusta GA
2021 F150 King Ranch, 2019 Expedition Limited
No. The part number I listed was only for four sensors. The six sensor wiring harness would be a different part number. I believe you may also need the park assist module to use all six.
antho
Anthony
Houston, Texas
2021 801A Raptor
They wire to the IPMA.
Zyvin
SC
2021 F150 Crew, FX4, Lariat
Yeah, looks like the IPMA runs it all now. I think the older model had a separate module.
From what I can see, I would need front and rear 6 sensor harnesses, button, front/side/rear side sensors (8), and maybe a new bezel depending on how the buttons install. That is assuming the IPMA is the same part # with/without active park assist.
Anyway, was just exploring the option. Would be much cheaper and easier to do just the front 4 as Omodan did. I could see myself doing all of that work to add active park assist and never using it, lol.
