FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS)
Catastrofe
Bob
FL
F350 Tremor
Great job on this widget…thank you.
What’s wrong with this picture? I’m surprised no one else has caught this.
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 0637A210-8FE9-437F-BE6A-DABC900AB963
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Hi Tonesto-
Is there a problem with the newer script 2022.03.10.2? My module data won't come up. If I try to do a "get data" it comes back with...
Errors Logged
save.JsonFile Error: Error:
"MYVIN#.json" couldn't be removed
Ruffiano99
Joe
NY
2021 f150
You dont have the “Left Front” and “Left Right” or the “Rear Front “ and “Rear Right” OEM tire package?
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
My Module data shows 2 “Unknown Module”s, one is BECM and one is SOBDMC. Is that normal?
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 9936F4AC-E540-422E-87FC-9BE33E5EB679
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) AC0B5DB6-C10B-4170-8D9E-456237DD629D
Bo15
Derek
NW Georgia
2010 F-150 Platinum 4x4
Hi Tonesto-
Errors Logged
You might be out of date. Same with tire guy. I'm on 03.14.0
tonesto7
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
I added more modules in the most recent update.
Make sure your running the latest
MikeYQM
Moncton NB Canada
I am, still undefined. Is it the widget that makes it undefined or vehicle/ford/FordPass?
tonesto7
tonesto7
Anthony
The widget. I just pushed out an update to address the other modules
don.mullins
Don
McKinney, TX
2021 F-150 3.5 Powerboost Platinum
Not sure when this stopped working, but with 2022.03.27.0 I can no longer see the OTA Update Info page:
Ford F-150 Lightning FordPass - Scriptable Widget V2022.XX (iOS, iPad, MacOS) 448E157B-A0F8-4AB8-AFBF-F63B5C1E779A
This used to work.
Thanks!
Pat
New York
2021 F-150 Lariat 502A SuperCrew 4x4 EcoBoost
This used to work.
Thanks!
That happened to me too, but I think it was because there was an update in progress or maybe a problem at Ford’s end. The Ford site gave me even less information than normal while that error message was up, but an update since came through and the widget is working again.
don.mullins
Don
McKinney, TX
I think you’re right - mine is now working as well, and it no longer shows the upgrade failure it had been reporting
jcaspar
Sacramento CA
2021 F-150 4x4
This used to work.
Thanks!
Mine has been like that for weeks.
tonesto7
tonesto7
Anthony
This used to work.
Thanks!
Yeah, that data is 100% on Ford's side.
I might need to add some more validation to the data to handle missing elements
Bo15
Derek
NW Georgia
On the Advanced Info page, under version SYNC4 v4.0.21281 the last updated shows "null" I thought it used to have the date 01/22/22. version 2022.03.27.0 Any meaning to this? Thx
