Ajzride
Alan
Houston
Eng
Guessing you haven’t figured out how to correct it? This is my TCU
That actually all looks reasonable, nothing jumps out at me as out of date. I'm back to being clueless.
Slappy McGee
South Caccalackey
2021 F-150 Powerboost
antho
Anthony
Houston, Texas
2021 801A Raptor
So my truck is failing to flash this MU5T-14H116-CA, but ive searched all my modules and cant find it in any of them. How can i find out where its missing from and how do i get it? Would a PMI fix this? Still trying to get the Module Update Repair to work. I assume it should be in either the Apim or TCU but neither of those have a line of code with that in it.
What module are you updating when it fails?
Slappy McGee
South Caccalackey
Have you tried leaving the Truck overnight? I know this sounds like tech support telling your to "Ctrl-Alt-Delete" as the response to every problem, but it worked for me when I was getting an InitializeCommsHost error on a GWM update.
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
I mean what does it look like on the screen compared to FP.... looks fine from what I can see.
Ruffiano99
Joe
NY
2021 f150
Yep i let it sit. Also made sure my usb and anything else plugged in was removed. Still getting the same failed to flash as you did. If been hung up on it for a few days now. In ur TCU does ur f188 line actually read MU5T-14H116-CA. Or one of the lines in TCU
Ruffiano99
Joe
NY
2021 f150
Attempted to do a PMI on the TCU and got this message… ??‍♂
Ford F-150 Lightning ECU module programming guide using FDRS 8B271BFC-DF3D-4CAB-82A6-74412D4336AD
FordConvert
Craig
Utah
2021 F-150 Lariat PB 502A
Builder
Dumb question: how does one “PMI” a module?
FordConvert
Craig
Utah
Builder
Getting this only when I attempt to update the GWM now. Anyone run into this?
Ford F-150 Lightning ECU module programming guide using FDRS C3D70F22-86BE-4928-9696-86C59775B8CA
Ruffiano99
Joe
NY
2021 f150
You may not have picked the right device when it asks how you are connecting to the vehicle. Make sure you selected the Nano or Mongoose whichever you are using.
FordConvert
Craig
Utah
Builder
It's the mongoose and this is the second truck I've updated. First truck is at BC. This only happens when I try to talk to the GWM for an update. Otherwise scans network and updates just fine.
