piratefan2
Does anyone know why my truck capped the power output to 64%? This happened while driving normally (60 mph, flat roads, 89 degrees).
Had you recently fast charger? That will heat up the battery and limit power until it cools back down.Does anyone know why my truck capped the power output to 64%? This happened while driving normally (60 mph, flat roads, 89 degrees).
Battery temp looks good on the gauge though.Had you recently fast charger? That will heat up the battery and limit power until it cools back down.
Do you have max tow?
Could have been a software fluke, or could have been protecting the battery from heat. Without more data I can't really say. Restrictions like that happen all the time in our Mach-e GTI had charged it on my level 2 charger for less than an hour. I do not have max tow.
You get power restrictions from charging on L2?Coi
Not from L2 specifically, but I'd it is too hot, or too cold, or the battery charge is too low (starts at 70%), or you are driving too fast (over 65) or the moon is blue on a Tuesday. GT is very sensitive.You get power restrictions from charging on L2?
I didn’t see any.Did it give you any warning lights?
I tried turning it off an and immediately back on. That didn’t help.Did it go away?
Did you try turning the truck off and on again? Not a great solution for a TRUCK, but may help with the troubleshooting.
Good to know! Thanks!Recently had the same issue and same percentage. No fast charging and wasn’t even post-charge, was after coming back to the truck from the store. Went away the next day and hasn’t come back since so I wrote it off unless it showed again.
Thanks. Hopefully, the Lightning, especially with Max Tow, is less sensitive.Not from L2 specifically, but I'd it is too hot, or too cold, or the battery charge is too low (starts at 70%), or you are driving too fast (over 65) or the moon is blue on a Tuesday. GT is very sensitive.
