Will a PowerBoost w/ Max Tow tow 9,810 lb. telehandler?
hevnbnd
Arkansas
2021 F150 King Ranch
I have a 9,810 lb. telehandler I need to tow occasionally. I am not sure what my 24' long bumper pull trailer weighs.
I also have a 12,100 lb skid steer that I need towed every once in a while. Thoughts?
Norris McCarty
Norris
San Angelo Texas
21 F150 Lariat 4x4 PB 7.2k FX4 17”Raptor Beadlocks
Own a RV dealership
I would go 3/4 ton. Probably 6.7 if towing at highway speeds for any distance.
chrisp993
Bloomfield Hills, Michigan
'21 F150 Platinum, '15 Audi S4, Spec Iron Mustang
Payload i.e. tongue weight is likely more relevant than the trailer weight - you need to know that number to answer the question but @ asssumed 10% tongue weight you will run out of payload before absolute towing weight on the skid steer in particular.
hevnbnd
Arkansas
I ordered a Sherline scale. I'll get some tongue measurements and report back.
Desertdweller
Gary
Scottsdale, AZ
2021 F-150 KR PowerBoost FX 4
Depends on the configuration you ordered which determines the Payload. Safe to say you should be around 1300 -1500lb payload. If it's just you in the truck then your weight plus tongue weight. Tongue weight is usually 10-15% of trailer weight. You should be able to tow a 12,000lb trailer, but you might be in trouble on payload. I.E tongue weight. For sure you will want a weight distribution hitch and air lift.
hevnbnd
Arkansas
Payload is easy...
Ford F-150 Lightning Will a PowerBoost w/ Max Tow tow 9,810 lb. telehandler? Payload
Matt604
Port Moody
Ford Explorer 2011->Ford 150 PB Limited 2021
If you make max payload work, what i notice here is Ford's towing guide states trailers >5000lbs require a WDH and GCWR is 17000lbs for PB. So expect you can tow the telehandler given a WDH but you cannot tow the skid steer since it + the truck would exceed 17000lbs. I don't know your truck weight but thought PB can be >7000lbs? Loading the trailer correctly (10%-13%) tongue weight would also be key with the telehandler. The sherline scale would allow you to get that perfect.
hevnbnd
Arkansas
I’m thinking the GCWR is 18,400. If I am reading this chart right. I have max tow.
Ford F-150 Lightning Will a PowerBoost w/ Max Tow tow 9,810 lb. telehandler? 36DFEA6A-B839-478A-A051-22A1FA952425
Looks like the curb weight is 5,517.
Ford F-150 Lightning Will a PowerBoost w/ Max Tow tow 9,810 lb. telehandler? EAFE1CFA-9DA8-4301-996D-108385D53CDE
Matt604
Port Moody
You're absolutely correct @hevnbnd, my mistake.
18400-5517-12100=783 left over i assume you have to deduct for what's on the truck?
I hope i got that math wrong again as it looks similarly challenging to 'legally' towing. I don't even see how Ford themselves could configure a PB per their guidelines to tow the max 12400.
hevnbnd
Arkansas
Yeah I don't think Ford knows either. If you notice that chart of the GCWR it shows 4x2 on both columns even though I suspect since the 4x4 column weighs more it is meant to be 4x4...
If i am understanding correctly I would also need to subtract the weight of my trailer from the 18,400 GCWR. My trailer comes in around 4,500 pounds. If that is correct then I would be looking at
18,400 (GCWR) - 5,517 (Curb) - 4,500 (Trailer) = 8,383 left for the load on my trailer...
Pappy
Mississippi
F150, Jeep
Do not forget to add the weight of the trailer. If you have a 12,500 # skid steer the trailer designed to carry it would be about 5,000 #. So no you are a 17,500 weight. A 1/2 ton will not get that done.
HandyMan
Denver, CO
2017 F350 Powerstroke
To add to the above comments about payload: the PowerBoost has about 200lbs less payload than a comparable 3.5 Ecoboost. If you're willing to give up the hybrid you will be more likely to be able to tow it.
I had the same concern towing an 8k lb camper + family and gear in the bed, so I downgraded to the 3.5 ecoboost for the extra payload.
Vrizzle
Candice
2021 F150 XLT 3.5 EcoBoost 502A Max Tow
Ford now gives you 300 pounds (150 each for a driver and passenger) in its 2021 payload and tow calculations. So you don’t have to subtract for the driver and if you’re both skinny for the first passenger either... good news though for those of us who were subtracting ourselves before.
hevnbnd
Arkansas
Where did you get this information?
