Key fob complaints
Regular150
Shawn
Purchasing
Yes, since PAAk has been solid for 6+ months, we don't Fob anymore. Mine is plugged in and set to 510am departure time to get cabin to 75 degrees before I leave.
When we come back from the beach for the day, I remote start 1/2 mile away and it's set to cool the cabin.
As far as the Fob to remote start, that's correct no button like on the ICE 150s.
I do get all of these buttons in PAAK
Ford F-150 Lightning Key fob complaints IMG_20220804_055936
Fast150EV
Fast150EV
Matt
Austin, TX
2015 F150 Lariat, 2022 F150 Lariat EV
What is PAKK? All I see is start/lock/unlock and horn/lights
PAAK (not PAKK) allows your phone to be a key (Phone As A Key). This is done via bluetooth connection. When you are close enough to the vehicle, the buttons greyed out (windows up, windows down, ...) all become active.
And, you no longer need a fob on you to drive the car. If you're lucky.
Fast150EV
Fast150EV
Matt
Austin, TX
My question is how did you get PAAK?
Regular150
Shawn
Purchasing
This is how I start my F150 remotely. Soon, we will also have the other features as well as Phone as a key.
But, Ford Pass does ket you remote start your vehicle from, well I'm my case I'm 290 miles away.
Ford F-150 Lightning Key fob complaints Screenshot_2022-08-04-09-32-35-33_f85a9dcae275ee1e0920d804e6924647
Ford F-150 Lightning Key fob complaints Screenshot_2022-08-04-09-33-01-10_f85a9dcae275ee1e0920d804e6924647
Ford F-150 Lightning Key fob complaints Screenshot_2022-08-04-09-33-06-27_f85a9dcae275ee1e0920d804e6924647
Snappy22
NJ
Honda Pilot, Honda CRV
Remote start works great with ford pass on my pro. Haven’t had any issues with the fob either. Obviously, the pro doesn’t have keyless entry or anything fancy, but works great for what it is.
Would you be able to post a pic of the Pro fob? Or key if one is needed with the pro? (Apologies I’m behind the curve on what the pro has standard even tho I was recently lucky enough to order one)
vbaker4444
Vic
2021 Mach E Select AWD
. Here you go. Range estimate is a little rough as I was ripping on it earlier today :p
Ford F-150 Lightning Key fob complaints 43BFF1C9-30FE-455B-8686-6201BE991973
Ford F-150 Lightning Key fob complaints 1C9DE172-C073-4691-B4A1-DE48E9A0DB01
broncoaz
Cape Cod, MA
2021 Bronco 2 door Badlands manual
I’d like to order an additional fob for my Pro. Can you see a part number on there anywhere?
broncoaz
Cape Cod, MA
The pro comes with two fobs. You need more?
You always need at least a third on Ford’s. If you have two fobs you can program a third, but if you lose one of your two they it means a trip to the dealership to get a replacement. First thing I do on any new Ford is buy and program fob #3.
cvalue13
Austin, Texas
‘22 Lightning ER Lariat
Fun-Employed
interesting tip
I assume the “blank” you’ll reprogram is far less expensive than one from the dealership?
LightingTroy
MI
Ford
I have a Pro. Try this number on the key fob. Super small. But I think it's...
NL3T-15k601-db
broncoaz
Cape Cod, MA
interesting tip
yes, $66. I have a buddy who works at a Chevy dealer who can cut the mechanical key for free as long as I have the key code.
NL3T-15k601-db
Thanks, that number worked. The place I bought my spare Bronco key from had one in stock so I grabbed it.
https://www.keylessentryremotefob.c...5truou9ljQvkuFNkzODWfprAX7kintsAaApgJEALw_wcB
