PungoteagueDave
I'm also wondering why the truck would "see" the incoming amps as somehow reduced. I think your charger may be screwy. The owner of TeslaTap told me (called on a facetime chat to show me that my adapter was working fine) - which was strange because it did the same thing on both of my Level 1 chargers - in Florida the day I picked up the truck, and the next day at our Virginia place - so I assumed it HAD to be the adapter. But he pointed out that although there is a small circuit on the low voltage side of the adapter, the main leads are straight-through - if you wiggle them slightly you can see that the larger connectors are direct passthrough between the Tesla connector and the truck - which says to my non-electrician's mind that it has to be throttled back at the charger?Excellent. Wonder if your HPWC had better tolerance or something, although I'm surprised that you had the error at 80A/100A, maybe yours was a little off and mine was way way off. Mine just refused to charge anything J1772 at anything more than 24A.
