Sitting at the airport, no charger
brewski
GA
2023 F150L Platinum
Yes
Anyone know how much trickle down with the truck can just sitting for about 10 days?
sd25
NJ
2022 F-150 Lightning Lariat ER, Rivian R1T
I wouldn't worry about it, the truck doesn't seem to experience much battery loss from sitting. I left it for 5 weeks unplugged, in my garage, and battery went down by only 2%.
But there was some pretty severe separation anxiety.
kab
Carroll County, MD
brewski
brewski
GA
2023 F150L Platinum
Yes
For either @kab or @sd25 , I presume the app shows charge status?
ChrisCon
The Hamptons, NY
My truck sat in my driveway during a two week trip unplugged and had 0% indicated power loss. I would not worry at all.
broncoaz
Cape Cod, MA
Mine was in transport for more than three weeks and the battery was at 90% when it reached the dealer. I’m assuming Ford charges them to 90% before they leave the factory.
Labs4Lightning
C
Labs4Lightning
C
Mine was @ 57% when it left Ford. (Via ford pass app)
Kev12345
Ram 1500
would outside temp come into play here? does the truck maintain optimal battery temp while the truck isn't in use?
ChrisCon
The Hamptons, NY
@ChrisCon & @Roy2001 I lose 1% per day. Curious what were your blend dates. One thing is my IR cameras do not turn off when truck is off. Could either of you photo your IR cameras when your truck is off? I’S the way to see your cameras.
My blend date was 5/20/2022 . Occasionally my security cameras pick up the IR flashing in my driveway ( my truck is almost always hooked up the the charger at night ) but I haven’t noticed it recently
ChrisCon
The Hamptons, NY
So I watched your video and conducted a test -- All of these results pertain only to drivers door IR.
When driving my truck the IR flashes rapidly
If I lock my truck and approach without the keys in my pocket, the IR is flashing at the same speed as your video.
If I put my arm into the window to film the IR, it sets off the alarm system. So it's clearly being used as part of the security system.
As far as I can tell, the Blue cruise IR (located adjacent to the center stack) does not go on on or flash for me if the truck is locked.
swesson
Scott
CO
I have taken three trips in the last four weeks, leaving the truck at the airport for several days each time.
The first trip lost 3 miles of range in 5 days
The second trip lost 2 miles of range in 4 days
The third trip lost 7 miles of range in 6 days
I am not sure why I lost so many miles the last time, but it is basically insignificant compared to the 20 miles of range per day that I often experienced with my Tesla Model X.
Keep in mind that range is an estimate. If the battery lost nothing, but temps dropped from 70 to 30, you would see a drop in range.
Reactions: kab
