theblunden
What's your trim/options?mine moved to built today as well.
XLT SR only option was the portable charging cord.What's your trim/options?
Ford CS told me the same thing and said it wasn't on a chip hold. Called my dealer they looked it up and VinView shows it at Ramp 59 not 51 and on a chip hold. Apparently Ford CS are contractors from what my dealer said so they aren't able to see everything.Take this with a complete grain of salt. 12/05 blend date. Not showing built status yet.
Ford Customer Service says that as of December 10, my truck was at Ramp 51 awaiting shipment. Estimated delivery between December 25 through December 31, and of course subject to change.
It is probably overly optimistic, but it would be great if the truck arrived in that window.
Yup my experience has been that not seeing does not translate to not believing and not making stuff up.Ford CS told me the same thing and said it wasn't on a chip hold. Called my dealer they looked it up and VinView shows it at Ramp 59 not 51 and on a chip hold. Apparently Ford CS are contractors from what my dealer said so they aren't able to see everything.
Your sticker is the first example I have seen for the 12/5 BW where spray in was a featureCan someone educate me a bit on window sticker? I am curious what these changes mean. @TaxmanHog you are the Yoda of the forum. Can you shine some light on this?
My original sticker:
My Current Sticker:
What is Rev number?
What the change from Michigan to Maryland means?
7-Memo(9) to 9 Normal?
006960 to 007772?
7862 to 18539?
My Current Sticker:
Why did CERT, TRD, BUMP, CAMP go blank? What do all of them mean?
883 to 364 ? Is this my new place in line because of my bed-liner?
9644 to 9670?
My Current Sticker:
CC59 to CJ59?
W to 2X?
REV = Rouge Electric Vehicle Center /Plant
Here is a snapshot of your 12/5 associates who've shared a VIN that I can analyze.
The majority of window stickers will show Michigan [MI] as the delivery location on the first night they are generated, sometime overnight they are revised to reflect a proper delivery state code.
During the revision run, all stickers listing spray-in-bed-liner, will see a variety of changes that you've touched on, they don't appear to affect the actual main line production order.
Sq-1 to the left of the blend date, changes for spray in trucks, but prior to that change your original value falls in line with a 12/11 Sunday blend day.
Sq-2 [to the right of your blend date] does not change during the mass revision process , it generally indicates the truck by truck sequence of what is being built on a particular day, the stepping value is not 100% consistent, and it always recycles upon reaching 8999
The ramp codes refresh based on the correction of the state and after treatment handling, it's where your truck will rally / stage waiting for a 18-wheeler or train car. Some MD deliveries have happened quickly, same day to 10-16 days at worst.
Same for me!! Even though it was built on 12/7 and at flat rock on 12/8 ready to shipThis mornings refresh showed me an update:
In production has a checkmark.
Built also has a checkmark with 12/15.
I guess it is time to reach out to the dealership and see what they see.
8 days! That was quick. One could say you are getting the Platinum treatment.This mornings refresh showed me an update:
That's the thing with averages. Some people have to be on the wrong side. Sorry to hear you have not been built yet.On day 34 of chip hood today… seen a bunch of trucks that started after mine get their chips already.
Friday morning update: showing built and estimated delivery 12/26/2022 - 1/1/2023Long time reader, first time poster. Blend date 12/5. Modules popped and tear tag on 12/7. Nothing since then. I do have spray-in bed liner so was expecting up to a week delay. Seeing you guys moving to built has me anxious. My window sticker has me in line at 254/461 (originally was out of 881 but moved later and hasn't changed since 12/7)
