Home Integration SystemWhat do you mean HIS?
We are in SD also, and use 2 x power walls to do exactly this. Even with 2 PWs, with a max output of 7.6 kW each, it was not enough to turn our AC compressors over. We had to also install soft-starts in both units. I don't think the truck will have enough amps to get things started.
With the PWs, we now never pull from the grid during the 4-9pm peak. We use the dedicated batteries to 'peak-shave'.
p.,s. SDGE peak on EV-TOU-5 is now $0.81 / kwh![]()
Do you notice any difference in the AC using soft start? Half the reason I'm justifying the Lightning is to be able to run AC in the summer if a monsoon knocks out power. So this is very good information your sharing, thanks!We are in SD also, and use 2 x power walls to do exactly this. Even with 2 PWs, with a max output of 7.6 kW each, it was not enough to turn our AC compressors over. We had to also install soft-starts in both units. I don't think the truck will have enough amps to get things started.
Not cheap, but neither is the HIS!and the two power walls cost roughly what to buy and install?
I don't, all i know is that now it takes less amps to start. Something like a 70% reduction. If we turn off the grid connection, the two powerwalls can now start both 3TON A/C without any issue. Before they would just buzz and do nothingDo you notice any difference in the AC using soft start? Half the reason I'm justifying the Lightning is to be able to run AC in the summer if a monsoon knocks out power. So this is very good information your sharing, thanks!
HIS is about 10k installed from SR, but I still woundn't work with Sun Run. I Have an indy guy installing my HIS and his friends HIS. I plan on passing his info around here as he'll likely be the SD guy to install a HIS without sun run soon.Not cheap, but neither is the HIS!
We paid 25k all-in after incentives for 2 x PW + 8 kW solar, 0.99% 10yr loan !
I am hoping that at some point tesla offers a V2G adapter plugin for powerwall/solar owners that can leverage the already installed equipment.
I'm definitely adding this to my list of things to get when I install my backup system. Thanks!I don't, all i know is that now it takes less amps to start. Something like a 70% reduction. If we turn off the grid connection, the two powerwalls can now start both 3TON A/C without any issue. Before they would just buzz and do nothing. Tesla installed the devices for no extra charge. I think they cost something like $300-$400 each if you were to do this on your own. The install looked easy though (<15 mins).
It was this brand. Not sure of the exact model, but that likely depends on your AC unit.I'm definitely adding this to my list of things to get when I install my backup system. Thanks!
Making the numbers work for you definitely depends on your situation, home construction, and environment.Yes, Ive got a 10KW system already. I like the idea of tesla wall but I don't see how it would pay for itself.
We have one of these devices and it seems to work well. It lets our 4+ ton A/C start when under battery power. It just comes up to speed a little slower. Ours was included as part of a Tesla installation.I don't, all i know is that now it takes less amps to start. Something like a 70% reduction. If we turn off the grid connection, the two powerwalls can now start both 3TON A/C without any issue. Before they would just buzz and do nothing. Tesla installed the devices for no extra charge. I think they cost something like $300-$400 each if you were to do this on your own. The install looked easy though (<15 mins).
