Running house AC from truck during Peak hours
dirtdiver
Steven
San Diego
Superduty F350, F150L 2022 Larait, Volt, R1200GS
Gents,
Im out here in San Diego where my electrical rates are at $.10/KWh midnight to 0600 but then 4pm to 9pm are at ~$0.63/KWh. 0600-4pm is at ~$0.45/KWh. We have shifted our truck to charging starting at midnight but i was spitballing converting my 2 house AC units to a 240v plug. Insert a 240v plug/outlet between the AC unit beside the house and the breaker box. When all systems are normal the plug goes to the outlet and to the Breaker box as it does now. However, if I get home at 5pm and the house is super hot, unplug from the breaker box and plug into the truck. In other words use the truck as a battery to shift my AC to cheaper power. It probs wold not happen but a handful of times per year but it might take the sting out of running the AC at 5pm for 3-4 hours. What do you guys think of this?
steve
Time shift the load to low TOU will save you money, but how much is the question, cost of the changes to the home AC wiring and the time to connect & disconnect, etc. I'm interested in how many amps your AC's pull on startup and steady run, would the trucks inverters handle that?
dirtdiver
Steven
San Diego
Yes good point. It is a cost trade - but for me to cut the wiring between the AC unit and the breaker to insert a receptacle/plug (if it is that easy) seems like something I could do with parts from home depot. You bring up a good point about the start up load. I hadn't considered that.
steve
Firestop
Firestop
Gents,
steve
Don’t forget that you have to address the bonded neutral…otherwise, your truck’s GFI will trip……….
chillaban
2022 F-150 Lightning Lariat
It’s a bit of work but it’s doable. With your rate delta I think you will end up saving money but it’s a question of whether it’s worth connecting and disconnecting your truck and flipping transfer switches all the time.
Amps
Bolt
Joneii
Central PA
F-150 Lightning, Tesla MY
Unless your house is really small, it is unlikely that the Lightning will power your AC unit. My RV ‘s AC is designed to run on 30 amps and it will when connected to my garage TT-30 outlet. However, the initial start up always trips the Lightning’s breaker. I am going to have to add a soft start device. That is just a small RV unit. I’m guessing your home unit needs more than 30 amps.
Tyler Durden
Cornelius
San Diego
Tesla Model S, F150 Lightning Lariat ER
It sounds like you have the EV-TOU-5 rate plan (I do as well). SDG&E raised all rate plans on 1/1/23. and EV-TOU-5 is now ~$0.15 off peak and the on-peak rates are ~$0.51 (winter) or ~$0.82 (summer).
Pitbull2o08
Ohio
I have it too. Don't forget the cost for delivery of each kwh.
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
Gents,
steve
I have a moderately high efficiency 4 ton a/c unit on 30 amp circuit. With proper capacitors my inrush is 26 amps with 19 amps running.
Measure power draws and plan accordingly.
Bigisland Guy
Ed
So Cal
Retired Old Dude
If you have a Southern Cal residence built post-1980 you might have the following situation: If you have central A/C the compressors usually has a 40amp min breaker plus the air handlers are usually on another breaker. So this is the first situation to overcome with only a 30A in the truck bed should you run into this. If you have A/C mini splits then you can make it work a lot easier with most of those types of units. Something to Keep in mind regarding A/C systems is that R410A refrigerant is going to be phased out and new compressors will most likely be needed. With the change in technology upcoming in A/C and bidirectional charging coming from companies like Emporia you might want to wait before doing the more extensive alterations. Good Luck
dirtdiver
Steven
San Diego
yes I do have TOU5. Raising our rates?! Gosh there is something very wrong going on at SDGE.
jk340
JK
F-150
Gents,
steve
Have you looked into solar and batteries? We have solar and batteries (Powerwalls) and do not buy electricity much of the year. Many months the electric bill has dropped from upwards of $600/mo. to $15-20/mo. In SF East Bay on sucky PG&E (another reason to have batteries!).
Pitbull2o08
Ohio
This is why I’m setting up the HIS and can’t wait for ford to allow energy arbitrage.
dirtdiver
Steven
San Diego
Yes, Ive got a 10KW system already. I like the idea of tesla wall but I don't see how it would pay for itself.
