Recommended Tires for Snow/Ice AND Summer
Lippy
CA
2021 F-150 Powerboost
I have Yokohama Geolandar G015s. So far they’re good in the dry, wet, snow, and ice. They also are quiet and weigh about the same as stock tires.
Pdxguy
La
Portland, Oregon
Mustang Mach-E FE, Toyota Tacoma, Audi
Wanted to (as promised) give people a quick update on how my Pirelli Scorpion AS+ 3 all-weather tires are doing.
First, some context – I purchased these all weather tires as added security for driving in snow, and my family with 4 drivers already has 2 cars that have full-fledged winter tires we swap out twice a year. Did not want the hassle of doing this for a third vehicle, and instead opted to go with all-weather tires given two other cars will always have winter tires if needed, but wanted to set the truck up to give my wife confidence she could use it in snow if needed.
First, the tires have been outstanding. I live near Mt. Hood in Oregon, and they handle well on snow, rain or dry pavement. Drove them through Portland after a major storm where multiple vehicles blocked the roads or could not function, and the truck coasted through it all.
Below is the reason I picked these tires over the all-season General Grabber ones based on Tire Rack reviews, and why I’m not giving more detailed performance info as it’s covered already. Grabber tires that came with the truck are on the top, and Pirelli’s are on the bottom.
Unfortunately, I swapped out the tires in winter and did not have a chance to compare mileage between the two as I didn’t drive on the Grabber’s enough, but I did capture some efficiency based on wet or dry pavement and temperature, so those of you who want to consider this can review.
  • Drive a 9 mile commute with mix of highway, streets and elevation in temperatures ranging from 38 degrees to 42 degrees AND numerous hills – 2.5 m/Kwh with wet pavement, 2.7 m/Kwh dry pavement. This commute tends to be downhill overall, and the return gets approximately 0.4 m/kwh reduction in all conditions.
  • Same 9 mile commute with temperatures 52-65 degrees – and dry pavement 2.3-3.1 m/Kwh.
  • Drive 85 miles on freeway at around 70 mph in temperatures ranging from 38-45 degrees on wet pavement – 1.6-1.8 m/kwh.
  • Same drive with temperatures 55-8/0 degrees and dry pavement – 1.9-2.3 m/kwh.
I realize my approximations are not scientific, but given all the variables of wind and pavement I combed through my records to give range that hopefully will allow people to make some decisions. Hope this helps those thinking of an all-weather snow tire. Based on my limited experience with the stock tires, I believe the range (at least for the commute) is similar, and there is no significant benefit to switch for that reason – but there is for the peace of mind in winter driving and reducing the hassle of storage and switching for pure winter tires. YMMV.
Stock tires that came with truck
Ford F-150 Lightning Recommended Tires for Snow/Ice AND Summer 1690655843108
Ford F-150 Lightning Recommended Tires for Snow/Ice AND Summer 1690655871496
Pirellis below
sotek2345
Engineering Manager
Pirellis below
That sounds like exactly what I am looking for, but I don't see them in the right size or weight rating. What tire size did you get?
Pdxguy
La
Portland, Oregon
geraulx
Laurie Andersen
Ford 150 2012
Senior Mechanic
If you only want to think about tires that are perfect for all-weather and snowdriving, then I would get the Bridgestone. I bought the WeatherPeak as last winter after debating between the Continental and CrossClimate2 (the Pilot Sport AS didn't exist then) and they are extremely hard in cold weather and almost dangerous in slush. The DWS has softer sidewalls and is overall less responsive, but that makes it a better winter tire. I put 20k miles on the Bridgestones since then and bought a dedicated winter wheel set with Dunlop WinterMaxx tires after the first snowfall.
