Drivers and passenger window flapping noise while up
Antdaddy
Tony
Sacramento
Black Lariat
Tech
Has anyone experienced intermittent window flapping of the windows while rolled up? I know it is loose between windows and insulation because I put slight pressure with finger against window and noise goes away.
EdRudy
Ed
Springfield, VA
I haven't experienced this issue, owned since mid November, 6K miles.
Ford Motor Company
Official Ford Account
Ford
F-150
Hi there, I'd be happy to look into your Lightning concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Maybe this????
02Reaper
GA
2022 Lightning XLT ER
Your issue is the piece I'm pointing to in the rear door. You can move that piece up and down and when the wind hits them right, that's the sound they make.
Ford F-150 Lightning Drivers and passenger window flapping noise while up IMG-7891
Samurai
Arif
La Verne CA
2022 Toyota Tundra Limited 4X4, Ford Fusion Energi
entrepreneur
I have the exact same issue, does anyone know of a fix for it? It gets worse on the drivers side if i slightly roll down the window on the passenger side.
Ford Motor Company
Ford
F-150
Good morning. Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this window noise concern? Thank you!
Samurai
Arif
La Verne CA
entrepreneur
VIN # 1FT6W1EV4PWG11420, Colley Ford, Glendora, CA 91740
Lucasw
Lucas
West Des Moines
2023 Lightning
Dentist
I've had my Lightning for just over two weeks now and have noticed the same issue. At higher speeds I notice a flapping and clapping sound. If I push on the driver side window it will go away. Has anyone had any luck getting a solution? Thanks
