- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
BREAKERS are not pefect, they work on the principal of 'HEAT' being the mechanism that causes the handle to TRIP the breaker ... this, though, can lead to weak breakers over time, especially those, like at campgrounds, where they are much more exposed to temp and weather, and campers tripping these breakers on and off on a sometimes daily basis - most breakers in your home's panel are almost NEVER tripped.
I've seen this personally at several campgrounds over the years, and the one where I used my "Y" Dual 30a to 50a adapter, the two 30amp breakers were VERY weak - I had to carefully and slowly push them up to the point where they would stay 'engaged' with the power... and dialed by adjustable EVSE down to accommodate those weak breakers.
Some breakers will hold up to a little more than they are rated for, many others won't. EVSE are using somewhat unique 'CONSTANT' power, which means that a breaker which is not quite still capable of holding up to it's limits will probably be a problem. You might use it successully for almost anything else, but not the constant heat created by 30amps of power flowing thru it constantly for hours and hours.
You can use a fan to help 'cool' the breaker. You can leave the panel's door open to give it more 'room' to breath, etc., if you really, really, need to push it to it's limits.
