Ladder/lumber racks
BuzzLightning2023
Los Angeles
92 Explorer,94 F150,06 Avalanche,05 F250,11 F150
I’m thinking about this rack. I occasionally haul long ladders, lumber, mouldings, etc., but want something I can use only when needed. Anyone have one of these? Thoughts?
BuzzLightning2023
BuzzLightning2023
Los Angeles
Ford F-150 Lightning Ladder/lumber racks IMG_3803
Ecstatic
Bret
Spokane
‘03 Highlander, ‘83 Landcruiser, ‘22 Lightning Pro
Temporarily retired
Did you buy this rack, and if so, how’s it working?
BuzzLightning2023
BuzzLightning2023
Los Angeles
Installed it today. Decent set of instructions with photos. It went together pretty well. I didn’t get to the part that cantilevers over the cab, and I’ll have to do some disassembly of the front rack in order to attach the extension. No big deal. One of the 8 clamps had bad threads and wouldn’t tighten. Called customer service and a human answered and said he’d send me parts right away.
Seems very sturdy. I’ll use it for ladders and 2-3 dozen 2x4’s, mouldings, etc.— nothing too crazy.
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
I wanted something that would fold down out of the way when I did not need it. I could not find anything so I made something instead. No tools required to fold it down. The cab over piece is detachable, the rear horizontal can swing out or be removed.
Ford F-150 Lightning Ladder/lumber racks PXL_20231223_002019679
Ford F-150 Lightning Ladder/lumber racks PXL_20231223_000325780
Ford F-150 Lightning Ladder/lumber racks PXL_20231222_235058425
Ford F-150 Lightning Ladder/lumber racks PXL_20231222_235046365
Ford F-150 Lightning Ladder/lumber racks PXL_20231222_235113960
Ford F-150 Lightning Ladder/lumber racks PXL_20231226_223545426
Ford F-150 Lightning Ladder/lumber racks PXL_20231222_235858518
BuzzLightning2023
BuzzLightning2023
Los Angeles
Dude, you’re a baller. I just finished clamping my removable one back on. I got a little smarter and got an impact bit holder and a 8mm hex tip to speed up the process. Nice job on yours!
AlaskaMike
'23 Lightning
I really like this setup. Would you mind sharing the parts you purchased?
How much of it did you have to weld yourself? I was thinking about something like this vs my own build with AL extrusion. I just dont know the proper hinges/quick bolts, ect.
Thanks!
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
I thought about doing it in aluminum but my skills are better with steel and parts are easier to find. I did all of the welding and had all the mild steel powder coated. The purchased parts are from McMasterCarr. Below is a rough list of parts, probably not entirely complete however.
stainless strut - https://www.mcmaster.com/catalog/33085T89
stainless strut nuts - https://www.mcmaster.com/catalog/3259T122
stainless cleats - https://www.mcmaster.com/catalog/33805T112
stainless adjustable clamp handles - https://www.mcmaster.com/catalog/6522K82
strut hinge - https://www.mcmaster.com/catalog/3505T12
weld nuts - https://www.mcmaster.com/catalog/90596A280
Mounting the strut was a little tricky, I had to cut away the plastic on the top of the bed rail to expose the stake holes then figure out a mounting bracket that could fit in the stake hole which the strut could bolt to. I ended up fabricating something like what is in these tie-down rings Ford Flush Fit Tie Down Anchors | 2015+ F150 | 2017+ Super Duty | BullRing USA
If you want some more detailed pics, PM me and let me know what details you are looking for.
AlaskaMike
'23 Lightning
Thanks, ill have to wait till my Elevate rails get in (t-slots) to measure, need a good adapter to build off of.
Get a headache plate off amazon?
thatsreallyclean
2003 f150 lightning pro
Window cleaner
That's an amazing ladder rack! I'm picking up my ford lightning pro this coming week. I have a window cleaning company and I was going to put a ladder rack on mine. I'm curious has it affected your range at all?
GarrettBlake
Garrett
Santa Rosa
2023 Lightning
At hwy speeds, range seems to drop about 10% without the cab extension and 15% with the cab extension. No noticable decrease with everything folded down.
thatsreallyclean
Window cleaner
Awesome thanks!
