- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
the MAX power output of the LIGHTNING will always be your limiting factor, which is 9.6kw or 40amps at 240 volts, with the HIS system. It will be limited to 30amps at 240 volts if you manually use the bed's 30amp outlet, instead.But the Lightning can power all that with the pricey system from SunRun. Right?
Your power needs in your home will ALWAYS dictate whether you can do 'all, or 'everything' at once... but, rarely do people do 'everything' when power is out, or a catastrophe has occurred - they generally then do the MINIMUM...
