HVJB in the Lightning
Biobob
Robert
Chico
2022 Lightning Lariat
The Lightning has had several recalls, not just one. Some, like the wiper motor, are shared with ICE F-150s. The rear lightbar issue has zero to do with not having a drain hole, it has microcracks that let water in.
Anotehr recall was for select 2023s with battery pack issues. A very small number (18) were impacted. This was tied to the fire experienced at a storage area at the plant.
Another recall was for close to 3,000 for having a software issue regarding TPMS low pressure warnings, because the value was set wrong at the factory.
The wiper motor recall involved potentially every Lightning made up through August 16, 2022. At a minimum, the part needs to be inspected to see if it is affected.
I don't know if I missed any, but like any vehicle it's more than 1.
The drain hole is to let the water out so the lenses don’t crack.
All the others you stayed are only if you are notified so I hope you’re not in those vehicles.
My truck was taken in and they checked with the factory.
I am waiting for the new lenses for my truck and none of the other apply to me.
I got a good one, except when it had some slight damage while it was being unloaded.
Hope you have better luck.
RA
Carl
Carl
Santa Fe, New Mexico
Physician
BioBob, are they doing the repair now or waiting on the solution for the back up lights?
NM1
Iowa
F-150 Lightning
I took a roadtrip to Chicago on 2/2/2024 with my F-150 Lightning. 7+ hours from home and two HVJBs died causing a catastrophic battery fault and left me stranded in a parking lot around midnight in the Chicago area. I am still waiting to get my truck back from being serviced. It is 2/13/2024.
Ford F-150 Lightning HVJB in the Lightning IMG_1258
FazaR150
FazaR
New York
Ford F150 Lightning
Hello ,
Is your truck fixed ? around how long it took ?also did they give you loaner ?
kind of in a same situation.
NM1
Iowa
F-150 Lightning
It was down 14 days. The dealer didn’t have a loaner and Ford has not reimbursed me for the rental.
FazaR150
FazaR
New York
Ford F150 Lightning
30+ days and still waiting on the fix , they are waiting on some parts . which are on backorder, guys whats my options now ? as their is no fix date in sight ?
invertedspear
AZ, USA
lightningcalcs.pages.dev
Are you still within your state’s lemon law period? Pursue that. Otherwise search the forum for the Ford BEV team phone number and see if they can help you.
Blochead21
PA
Black 22 XLT 311pkg
Here’s a few I’ve saved.
Ford EV (800) 334-4375
OTA help (833) 926-3233
BEV (800) 392-3673
Pass app (855) 542-7821
In service car techn... (800) 392-3673
ota dept (833) 389-0848
FazaR150
FazaR
New York
Ford F150 Lightning
i believe so and asked the FORD Proactive Customer Dealer Advocate to start the buy back process , lets see when and what they respond . so far my primary contact is Proactive Customer Dealer Advocate, keeps me updated on the situation .
marc_hanna
Marc
Nova Scotia
Following this thread. I seem to having an issue with the HJB also. Problem occurred my second day of owning the truck. They "fixed" it yesterday, salesman took it out to test on a DCFC and the fault immediately returned.
