JL13
- First Name
- José
- Jul 3, 2023
- Chandler, AZ
- F150 Lightning Platinum
- Occupation
- Retired
The tail light assembly is actually a full LED tail lights with some electronic circuitry inside to provide the regular parking LED light working when the headlights are turned on, but also the brighter LED light used for braking and turn signal indicator. At the bottom of the tail light assembly there is a cavity where the BLIS radar sensor sits. My new Ford tail light part number is: NL3Z-13405-H (no BLIS radar module included) for the driver side tail light.Can't figure how to post a pic from my phone yet, but I bought NL34'-138504-BG.
It's the whole unit with sensor.
My original tail light part number was: NL34-13B505-BF.
I hope that your $15.00 dongle will work for you; according to some users of the cheap dongles are not reliable enough especially for attempting to reprogram a module.... Hopefully you will be able to read the DTC codes and clear them....
I myself still attempting to learn how to use Forscan tool when I need it.... I have checked for the DTC codes and cleared them successfully to make sure that the truck is working correctly; but I have not tried to reprogram or modify any modules at all by concern of messing up some stuff especially while the truck is still under warranty coverage from Ford.
