CluckFam7
Hi all,
First time poster, though have read more posts on this topic than I care to count.
I’m trying to understand a proper setup to use the PPO’s 240V outlet as a home backup. I want to do it the “proper” way, meaning to code and safely without hacks.
From what I have gathered, getting a neutral switching transfer switch like the Generac 6852 is the “proper” way to do this.
However, I have some questions:
First, I saw one thread on the 6852 that alluded to this and it prompted me to dig further. On page 7 of the Generac 6852 owners manual, it says “Portable Generator Grounding Requirements. The Upgradeable Manual Transfer Switch is designed for use with portable generators with a bonded neutral, and used as a separately derived system. A grounding system and a grounding electrode system shall be connected to the ground terminal of the portable generator. See NEC Article 250.30(A)(4) and (5) for code compliance.”
I am unclear what this means exactly; does it mean that the truck needs to have its own grounding system (like a ground rod?) to connect it to physical ground when used on the transfer switch? Does this mean a typical setup where the truck doesn’t have this is not code compliant or has a scenario that is not protected against?
Second, with the Generac 6852, would I be able to use a normal portable generator, which I understand has a floating neutral, as well?
Thanks in advance. I fully intend to have a qualified and licensed electrician do the install, but I simply want to arm myself with information. I know everyone including licensed professionals are human, so I’d like to be able to have a general understanding of what is correct vs not vs blindly trust.
