What is the base price of a 2024 Flash?
climateguy
Ferndale, Washington
2021 Bolt, 2024 Flash, MaxTow
The Long MacArthur dealer in Kansas posted a video April 9 2024. At 1:23:39 he says he is reading from a Ford to dealer communication that announces the recent price reduction for various Lightning models, i.e. specifically the Flash. He says the new base price, exclusive of destination charges and options, is $67,995
I'm looking at a Flash window sticker today, May 1 2024, which lists the base price as $69,995. Can someone explain?
Ford F-150 Lightning What is the base price of a 2024 Flash? base price flash
The window sticker was generated before the price reduction.
climateguy
climateguy
But the old base price for a Flash was $5,500 higher
climateguy
climateguy
When I called the dealer who posted the sticker online, he said the vehicle was ordered in October 2023, and it is sitting in Dearborn at the moment, presumably produced but not ready for shipment.
He said the practice is, in a case where the MSRP has changed, that a revised window sticker is typically available once the vehicle arrives on his lot. I said if someone contracted to pay him the MSRP, but only the MSRP that was on that revised window sticker, to reserve the vehicle now, would he accept. No, he said. Hmm. He said he thought if someone ordered a new 2024 Flash now, it would take six months to arrive....
$69,995 was the original price when announced last October. In February they raised it to $73,495. Then a month ago they lowered it to 67,995.
climateguy
climateguy
Thank you.
Now, I'm wondering if the MSRP is what a person should offer to pay to get a new 2024 Flash today, in the Pacific Northwest.
Zaptor
.......... Trophy husband
Thank you.
I don't think there are many, if any, that have been delivered yet, and there almost certainly won't be any Ford cash on the new trim. I also think dealers won't be discounting 24s much with 23s still on the lot. I'd wager there's a better deal to be had on a 2023 Lariat ER than a 2024 Flash and the Lariat will be better equipped, and come with several options, including the Charge Station Pro (and faster home charging) that the Flash won't have (there's a full list here somewhere, it's a lot of things!). I'd shop dealers against one another and try to pick up a Lariat ER in the high 50s maybe low 60s after paperwork and get a better truck for less money...
Good luck 🍀
-Zap
climateguy
climateguy
I... think dealers won't be discounting 24s much with 23s still on the lot. I'd wager there's a better deal to be had on a 2023 Lariat ER than a 2024 Flash and the Lariat will be better equipped, and come with several options, including the Charge Station Pro (and faster home charging) that the Flash won't have (there's a full list here somewhere, it's a lot of things!). I'd shop dealers against one another and try to pick up a Lariat ER in the high 50s maybe low 60s after paperwork and get a better truck for less money...
Good luck 🍀
-Zap
Thanks for your good advice.
What caught my attention when considering a 2023 or 2024 Flash at this point is the heat pump in the 2024.
My experience with my 2021 Chev Bolt EV is that the kwh per mile drops off rather dismayingly once the resistance heating the Bolt has is used in the colder seasons, even though I live in the temperate Pacific Northwest. Even though my main use for the Flash will be towing an RV, and I don't anticipate RV'ing in the winter, I do like the idea of anything that will increase the range when towing in spring and fall. That doesn't mean I like the idea enough to pay a small fortune for it, so thanks for making a lot of sense with your advice.
As far as the Charge Station Pro goes, I expect that my existing 40 amp 220v home EV charger can easily keep up with the limited use my Flash will see around town. I have a 200 amp service to my home, and what with my plan to switch from gas heat and hot water to a heat pump hot water tank and and heat pump heating I'm wondering if I could also go for an 80 amp Charge Station Pro without having to upgrade the service to the house.
Zaptor
We are also on 200A service with all electric appliances. We switched to a heat pump hot water heater last year and have a 3 zone mini split installed that gets inspected and turned on next week, so sounds very much like our setup. We have the FCSP on a 100A breaker making 80A to the truck and wow, is it fast. Also have an Emporia charger with 48A charging and load management. We've had both of our Lightnings charge at night, during time of use and have never popped the main breaker, so I do think the FCSP would likely work for you. An electrician can do the load calcs and tell you for certain whether it will be stable and safe. Hope you find the right truck for your needs, post it up when you do!
Cheers
-Zap
climateguy
climateguy
I'm 74. I've bought exactly one new car in my life. I felt like the dealer on that one took advantage.
I've told a Ford dealer I would like to buy a Flash his dealership ordered long ago (Oct 2023) that Ford has built as of January 2024. It is still sitting in Dearborn and the dealer says all Ford will tell him is it is a "quality assurance" hold. Here is the dealer's price offer:
Ford F-150 Lightning What is the base price of a 2024 Flash? Dealer offer
Junglemutt5
Matt
2023 Chevy Bolt
sales
Cheers
-Zap
Zaptor,
I was told that code only allows for an incoming power source (such as solar or in this case bidirectional charging) of a maximum of 20% of the panel size. For a 200A service this would be 40A. I have a solar system with a 40A breaker and 200A service so this seems to support that. How were you able to safely get around that with a much larger breaker? My understanding is that too much current can overload the panel bus bars. Thanks
Junglemutt5
Zaptor
Zaptor,
Junglemutt5
Hi Junglemutt5,
I have a large solar array (24.32kw) that I had professionally installed, but my understanding is that the power I generate is fed directly back to the grid, and metered, and that 100% of my power comes from the grid via 1:1 net metering, so that massive amount of energy is never running *into* my panel. I believe my solar array has a 200A breaker in a panel outside, with a shutoff. As far as the FCSP, I also had that installed, but *not bidirectionally* so no HIS, but both projects were permitted and inspected. As far as a 20% rule, I am not familiar with that, and it must not apply in the case of my configuration... I'm reasonably confident that the busbars in a 200A panel will support 200A/160A, or it couldn't be rated that!
Cheers,
-Zap
