2wheeltraveler
- Oct 4, 2021
- Austin, TX
- 2022 F150 Lightning Lariat Rapid Red
Mine are about 82".... it was a quick check, may be off by an inch or 2.Is there any chance one of you can either check the box (if you have it) or the length of the steps.....they did send the correct motors/wiring box but the second box says PSR72 72" power rail step and I'm wondering if they sent the extend cab steps with the crew cab kit....then again they do work but look shorter than those posted here.....first pic is with steps removed, second is with side steps on![]()
