Heated Steering temperature adjustable?
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
I know my dealer only retrofit heated steering wheels only in summer
But after it was installed last week, I found it's not warm enough
Is there something to adjust via forscan? Or am I having a bad steering wheel?
Thanks,
davehu
hot springs, AR
Thanks,
somethings not right. Mine gets very warm very fast.
Formerly
NY
Ford Lightning 2022
Construction Estimation
There are noticable stages of heat though. It's toasty when turning it on, but it fades to a lower heat setting after a period of time. Not sure what the time length is, maybe 10-15 min?
G-Zeus
Garth
Massachusetts
F150 Lightning Lariat SR
Yes you can adjust it in Forscan. I jacked mine up to the max. I can’t remember where, but once you load it up you should be able to look around the modules and find the steering wheel temp adjustment setting. I believe you can also control the length of the heat but I did it 2 winters ago so my memory is a bit hazy on that!
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
ytwytw
Toronto, Canada
found how to change it via forscan
Ford F-150 Lightning Heated Steering temperature adjustable? 1719244061659-ul
it was set to 30C, now I change to 39C and its warm enough for me
BennyTheBeaver
Thank you for sharing
