$17.99 Amazon Pro/XLT base tailgate dampener installed…
Nklem
Norm
Maine Coast
23 Lightning XLT SR, Max Tow, 24 Silverado EV 4WT
Just finished the tailgate dampener. Posted on the FB forum last week at $17.99. What the heck for that cost, Cheaper and easier than the ford OEM that needs to be painted…and easily put back to stock. Thanks to who posted this on FB. Less than 30 mins alone. Be sure to realign the lower hinge and mark the location with something before you loosen the bolts, put it back in the same spot, tricky with one person, also remove the bottle opener and finally upgraded the China M8 bolt to stainless for $1.59 at Ace.
Ford F-150 Lightning $17.99 Amazon Pro/XLT base tailgate dampener installed… IMG_8959
Ford F-150 Lightning $17.99 Amazon Pro/XLT base tailgate dampener installed… IMG_8960
Ford F-150 Lightning $17.99 Amazon Pro/XLT base tailgate dampener installed… IMG_8963
Ford F-150 Lightning $17.99 Amazon Pro/XLT base tailgate dampener installed… IMG_8961
Ford F-150 Lightning $17.99 Amazon Pro/XLT base tailgate dampener installed… IMG_8964
Ford F-150 Lightning $17.99 Amazon Pro/XLT base tailgate dampener installed… IMG_8962
Ford F-150 Lightning $17.99 Amazon Pro/XLT base tailgate dampener installed… IMG_8967
Ford F-150 Lightning $17.99 Amazon Pro/XLT base tailgate dampener installed… IMG_8968
Maxx
I love to get one of these but I want to keep my tie down too. Anyone knows of a replacement for tailgate tie down that allows installation of this?
Blochead21
PA
Black 22 XLT 311pkg
just get the oem damper. It usually $80-90 and requires installation behind the right taillight.
onish5
San Jose, CA
2023 Ford F-150 Lightning Pro
The OE tailgate dampener mounts in the pocket behind the right tailgate light assembly and replaces the right hinge receiver only. The other mount point is already there in all trims. After install, the only thing you can ever see is the hinge receiver, which is only visible with the tailgate open. The dampener discussed above is the older style dampener that is exposed.
FreshDaddyE
Raleigh
2023 F150 Lightning
Before I go tearing into the taillight assembly to find out for myself, does anyone know of the OEM damper is compatible with the power tailgate?
The one OP shared is nice, but I too would like to keep it clean with the tie downs and bottle opener.
Old school me hates the power tailgate. It’s slow and a bit temperamental.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Best $18.00 you can spend. Turns your tailgate into a soft close toilet seat. Yes you need to remove the tie down but in 30 seconds the 2 screws can be removed and the tie down can be installed . Remember to use the tie down the tailgate needs to be down anyways.. so therefore there would be no interference. Once done with your hauling , tie down load, another 30 seconds, it can be removed. So no big deal.
1 word of advice, use the included locktite to also glue the threaded strut rod to the heim joint threaded connection. Mine loosened up and unscrewed 2 months later.
Rick
FreshDaddyE
Raleigh
2023 F150 Lightning
If the interwebs is to be trusted…
Ford F-150 Lightning $17.99 Amazon Pro/XLT base tailgate dampener installed… IMG_5885
I weep.
Looks like it’s the Amazon route! Thanks for sharing OP!
Blochead21
PA
Black 22 XLT 311pkg
The dampers are for non-powered tailgates only.
Maxx
Blochead21
PA
Black 22 XLT 311pkg
Maxx
Blochead21
PA
Black 22 XLT 311pkg
Have you used this part? They say it does not fit my Pro
Yes I’ve installed this PN. You can always check via fords part website with your vin if your concerned.
Maxx
Thanks for your help.
