Lighted Running boards for Sale. Reduced Price ($150)
JDub
JDub
James
Oceanside
No, I'm sorry. Shipping is too costly.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Any idea if they work on the flash, or would they need to be programmed to light up?
They’re Located in Oceanside?
Rick
JDub
JDub
James
Oceanside
Yes, I'm in Oceanside. I'm not sure if they would work. We could find out.
Albern
Second star to the right
I want these but I'm also in Canada.
2024 running boards aren't lit and I really want to change that. Does anyone know if only the light element side is available for sale from Ford?
jdmackes
2023 F-150 Lightning Pro
I know you can add lights to them with little issue. I bought a set of led lights to go on mine and a dongle to connect to the power supplied by the truck, but I haven't bothered with putting them on yet.
derelict
XLT ER
As long as the connector is there, you can hook up the lights. Many if not all of the ICE F150s have that connector too. When i removed my OEM lighted running boards I was looking for a cap for that connector, then I came across this video:
I ended up doing the strip lights like this guy did with that same connector. So look under your truck and if you have that connector, then everything will just bolt and and plug in that connector, it should be good to go.
However, there is a small possibility you may need to enable something in Forscan, there is probably some info on that in the Forscan subforum.
