Bed Cap Wiring - Wiring Brake Light/Signals
Would you tackle this project yourself?
  • Yes
  • Are you crazy?, Nope
Results are only viewable after voting.
cdnphotog
F-150 Lightning Flash
Other than don’t cut any of the orange wires…
I’m about to install the wiring for the rear brake light/signals on my new TUFCAP that is on my new truck - yikes!
I used to just tap into the trailer wiring harness. Now I understand it confuses the truck into thinking there’s a trailer attached.
My new plan is to tap into the wiring harnesses of the tail lights.
I will also run a fused 12 gauge wire from the 12 V accessory battery straight to the accessory box in the cap. That distribution box switches inside and outside LED lights there’s are also USB and 12v accessory taps.
Any comments on potential pitfalls?
How about a route to run the wire from the accessory battery back to the truck bed?
Ford F-150 Lightning Bed Cap Wiring - Wiring Brake Light/Signals IMG_2619
Ford F-150 Lightning Bed Cap Wiring - Wiring Brake Light/Signals IMG_2621
Ford F-150 Lightning Bed Cap Wiring - Wiring Brake Light/Signals IMG_2615
TRCarr
Tom / TR
Salmon Idaho now
‘23 Lightning Lariat black
I
installed my SmartCap 3rd rail light. Fuse 15 under dash R of passenger foot well. Works perfectly.
cdnphotog
Thanks!
This "fancy" cap also has a reverse light and signals on it.... Brake light is a must but I would like to access the others too.
I think there's also the "CHMSL" wire but I'm not sure if I need the CHMSL filter harness to use it.... any one know the harnesses function?
Fuse 15 if all that fails!
