URGENT: Dec Android update for Samsung breaks PaaK
Certainly sounds like we can lower our DEFCON level now
Folks affected should look at system / app notification list, look at the not approved filter, switch on those apps that were switched off, flipp them back on.
Ford F-150 Lightning URGENT: Dec Android update for Samsung breaks PaaK 1734265725038-si
Ford F-150 Lightning URGENT: Dec Android update for Samsung breaks PaaK 1734265745832-85
Also check notification categories for proper settings, mine were unchanged.
Ford F-150 Lightning URGENT: Dec Android update for Samsung breaks PaaK 1734273627218-6d
Ford F-150 Lightning URGENT: Dec Android update for Samsung breaks PaaK 1734273669265-gq
It will not connect to, or start, our Mach-E.
Do you have to pick which vehicle you want to interact with?
I don't have multiple Ford's, is this seemless or requires interaction by the user?
Ford F-150 Lightning URGENT: Dec Android update for Samsung breaks PaaK 1734266039769-i1
Yes. And it makes me unnecessarily angry.
When going from one vehicle to another, you have to switch vehicles in the app, shut off Bluetooth and then turn Bluetooth back on. And even then, the first time you go to "start" the vehicle, you get a "key not detected" fault. You have no choice but to put in your backup code or dig the FOB out. Then it will work every time until you switch vehicles again.
