Tire Pressure Warning issue
anewbe
Tony
Waco, TX
Okay you Lightning Wizards, The tire pressure warning keeps telling me I have a front right tire problem. It shows the same pressure as the other three tires and the pressure changes equally on all four tires as the temps increase. I suspect it could be fixed by disconnecting the accessory battery and resetting the system. I really don't want to take it to the Dealers (quite a distance). Anyone else suffered the same issue?
My guess is intermittent TPMS sensor. Rotate the tires. If the message follows the tire it's a bad sensor. If it doesn't follow the tire it's on the other side of the TPMS system, which I'm less familiar with.
Ford Motor Company
Official Ford Account
Ford
F-150
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
NCA Lightning
Utah
2022 Lightning
That happened to me when the tire techs underfilled my summer tires this year. About 3 months after the summer tires went on, I had a tire warning on the front right tire come up when all the tires read 34 psi from the truck's dash screen. I filled them to 40, and the warning went away.
