XLT OEM Bed Lights Install
BhamDCam
Birmingham
2023 F-150 Lightning Pro ER
Success! I now have working bed lights on my 2023 Pro ER. I do NOT have the Tow Tech or Max Tow packages on my truck. I wanted to type everything up here though to hopefully clear up some confusion about exactly what is needed.
Before I get started...huge, huge shoutout to @Itaintfastenough (Woody)! Not only did he send me the pigtail I needed, but he also answered many text messages and helped walk me through the process when I had questions.
First, I installed the bed lights and wiring harnesses mentioned and listed by @KurtsRPMGarage in his video here. Follow his instructions for the install and required FORscan changes first.
Next, I stumbled upon Woody's post here about why sometimes the bed lights work and sometimes they don't. In short, if you've added the lights, harnesses, and switch in the first step and they still don't work it is because the BCM is missing two connection points (wires) going to the new harness at the back of the truck. In other words, you have to physically run two wires from inside the cab near the floorboard on the passenger side all the way to the back driver side of the truck. I made a quick video to show this here.
Wiring:
  • The first wire will tap into the existing wire at Pin #8. Should be a blue/white wire. The other end of the first wire will tap into the blue/white wire on the switch wiring harness you installed at the back of the truck.
  • The second wire will connect to the new pigtail you add to Pin #9. The other end of the second wire will tap into the green/orange wire on the same switch wiring harness. Be aware that the wire color on the switch wiring harness may be green/blue instead. That's how mine was.
Ford F-150 Lightning XLT OEM Bed Lights Install 1735785018423-rt
Supplies:
  • 18 gauge wire
  • T tap wire connecters. You only need 3 sets.
  • Butt splice connecters. You only need 1.
  • Pin connector, part number 1924955. Can buy from Digikey here. You only need 1. More info about the connector and the BCM "plug" at @rio's post below here. Thanks, Rio!
  • Small flathead screwdriver (to remove connectors from the plastic housing on the BCM plug)
  • Wire strippers
  • Crimpers
  • Electrical tape
  • Zip ties
  • Heat shrink tubing / heat gun (optional)
Important notes:
- Zone Lighting. This can be confusing because AFAIK everyone has the "Zone Lighting" feature on their screen in the truck. This is what I referred to in the video I made. However, I believe the best way to confirm if you have the Zone Lighting (with the required wiring preinstalled from the factory) is to check your windown sticker. Mine does not have the Zone Lighting feature on there. I believe it comes with the Tow Tech package.
- Tow Tech package seems to be the missing link for the 2022s/2023s. If you don't have Tow Tech then adding the bed lights probably won't work until you add the two extra wires.
- IIRC, the 2024s and newer may differ from the wiring on the 2022s/2023s. Something to keep in mind.
- To run the wires from inside the cab to the outside I simply ran it through the cab vent. I figured this would be fine since this is what Starkey recommends if you buy their bed light kit. Plus, that meant that I didn't have to drill through the floor of the cab. Pics below.
Ford F-150 Lightning XLT OEM Bed Lights Install IMG_1418
Ford F-150 Lightning XLT OEM Bed Lights Install IMG_1419
Ford F-150 Lightning XLT OEM Bed Lights Install IMG_1441
Overall, it isn't that difficult of a project, but is a little time consuming. Ping me if you have any questions and I'll answer as best I can!
EDIT, 1/6/25: Added pin connector part number and links to the supplies list.
watts/up
23 Pro SR
Next, I stumbled upon Woody's post here here about why sometimes the bed lights work and sometimes they don't. In short, if you've added the lights, harnesses, and switch in the first step and they still don't work it is because the BCM is missing two connection points (wires) going to the new harness at the back of the truck. In other words, you have to physically run two wires from inside the cab near the floorboard on the passenger side all the way to the back driver side of the truck. I made a quick video to show this here.
Wiring:
Supplies:
Important notes:
- For the pigtail you need for Pin #9, I'm not sure what the technical size is, but I've also included a picture of it below in case it helps.
So great that you were able to figure it out. I think that quite a few people on this forum will be pleased to read this.
BhamDCam
Birmingham
Well, Woody figured it out! I just wanted to write up a step by step guide for more of the specifics. Just a simple way I can give back to this community that has answered so many of my questions in the past.
rio
CT
2016 Chevy Volt, 2023 F150 Lightning Pro
Wiring:
Supplies:
  • 18 gauge wire
  • Wire strippers
  • Crimpers
  • Electrical tape
  • Zip ties
Important notes:
Amazing! I installed mine last year and have been waiting for somebody to figure out the missing wires. So I've had non-working bed lights in there this whole time. It makes sense that the missing link is Tow Tech. Great writeup! I will do mine next week. Will let you know how it goes. Thank you!!!
rio
CT
It would be nice to know the part number for the crimp connector needed for the BCM plug - I wonder if it's the same as the IPMA plug (DigiKey p/n 1924955). Perhaps @ZSC100 knows the answer to this?
BhamDCam
Birmingham
Yeah, knowing that would be super helpful. If anyone finds out the part number then I’ll update my original post to include it.
Narrator
23 Pro
I'm glad we got some more documentation on that method. I saw Woody's solution on the other thread and I was hoping someone would do a detailed writeup. That said, I'd be curious to see how the factory routed that wiring on somebody's truck that came with tow tech. Probably part of some larger and now completely inaccessible harness.
As it stands, I'm probably going to skip doing this job and return the lights I bought on Amazon. Anyone wanna buy some lightly used harnesses and a button? :LOL:
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Sorry I don't know, but with all the pins I've dealt with on this truck I'd imagine it's one of them. Is this the one you're after:
Ford F-150 Lightning XLT OEM Bed Lights Install 1735842811352-y5
Does look familiar, but to be sure someone needs to take some much more accurate measurements with a caliper.
BhamDCam
Birmingham
Ford F-150 Lightning XLT OEM Bed Lights Install IMG_1442
ZSC100
Zach
Tulsa, OK
Electrical Engineer
From my post here:
https://www.f150lightningforum.com/...lert-to-2022-f-150-lightning-xlt.14870/page-6
Is this the same female socket that I pulled out from connector C265 that leads to the IMPA for the CCM. If you suspect so I can pull one out of a WAGO on my truck later tonight and accurately measure all of it. We need more measurements like length of the square socket, both dimensions as the one you took. and overall length. Also, detail on the side that catches in the plastic retainer. See this one:
Ford F-150 Lightning XLT OEM Bed Lights Install 1735847911296-wq
That is the female pin where the CCM connects to the IMPA at C242B. Does the one you're after have that detail on the end and side?
BhamDCam
Birmingham
From my post here:
@Itaintfastenough sent me the pigtails in several different sizes since we weren’t sure which size was the correct one for this application. I have no idea which plug he got this specific pigtail from. Woody, do you remember?
Here are more measurements. Does this help?
Ford F-150 Lightning XLT OEM Bed Lights Install IMG_1443
Ford F-150 Lightning XLT OEM Bed Lights Install IMG_1444
Ford F-150 Lightning XLT OEM Bed Lights Install IMG_1446
Ford F-150 Lightning XLT OEM Bed Lights Install IMG_1447
rio
CT
Found it! I took the BCM connector out and found the part number. It is exactly the same as the IPMA pins. Here's everything I found:
All parts are made by TE Connectivity
The big blue connector with the grey lever is p/n 1924346 (link here). It holds two 26-pin housings that slide in.
The 26-pin housing is p/n 1924136 (link here (for the top piece) and here (for the bottom piece)).
The receptacle terminal (i.e., pin connector) is p/n 1924955. This is the same pin connector as the ones in the IPMA connector. There's a few different variations based on packaging and intended wire gage. For 18 AWG here is the link: https://www.te.com/en/product-1924955-4.html. Can buy on DigiKey here. I'm gonna order some and get this done. Wish I had more leftover from when I did the ACC mod.
