Madasahatter1138
Steve
Vancouver Island BC
Ford Transit
Electronics Tech
What fuse did you use and/or did you run your wires away from the antenna?
I believe it was 48? The same one shown in the install videos, I followed them exactly so my wires run very near the antenna. I presumed I would have no radio so didn't even try using it for a few weeks until I happened to turn it on, and all my preset stations sounded great. Now I have AM after an update, and the hockey game comes in just a lousy as it does on every other radio I own 😆
jimfigler
Orchard park, NY
What fuse did you use?
There is a youtube video showing how to modify the f150 ICE wiring harness so no fuse connection required.
link does not work. search Martin Rebuilds on youtube
zinkscott
Christian
2023 F-150 Lightning Platinum
Cloud Engineer
Had no idea the chipping was covered under warranty. Definitely looking into that and the emblem, thanks!
Nice color :)
Nice color :)
He might just have a nice dealer. Rock chips aren't covered under warranty. If you do get it replaced, have a PPF applied to it or it will just chip up again.
Heds43
Hendrick
F150 and F250
Instrumentalist
I love the pics
Heds43
Hendrick
F150 and F250
Instrumentalist
Heds43
Hendrick
F150 and F250
Instrumentalist
Martin
2023 Ford Lightning, 2021 Mustang Mach-E GTPE
I have done many of these. There is a putco harness that needs modified to get it to work well. Check out both of my videos on this...
Altivec
Just did mine and I haven't noticed any radio interference. The only thing I did that was different is that I added shrink tubing over the plug-in joint. Don't know if that had anything to do with it (should have probably tested before and after. oops). But anyways just wanted to mention that radio interference is not a for sure thing with the Putco emblem.
