Home Assistant - Ford F150 Lightning Dashboard.
zinkscott
Christian
2023 F-150 Lightning Platinum
Cloud Engineer
This one is nice as well. Mind sharing? Or was this one already posted earlier?
I've taken parts from quite a few - one originally posted here I believe. I don't mind sharing. I also have some templates made, included in the GIST.
EDIT: Make sure to change your device ID in the `navigation_path` lines if you copy these.
queuewho
Western PA
F150 Lightning Lariat SR
I set mine up about 2 months ago and it’s been working fine.
You must clear out any downloaded version via HACS and then manually install 1.70 per repo instructions.
EDIT: image
Did you just scp into your backend files and copy 1.70 into some specific folders? Didn't see specific instructions on the manual install.
IIRC I just downloaded the files from the GitHub site and then overwrote the same files on my HA box but keeping my existing token file there.
\config\custom_components\fordpass
queuewho
Western PA
Thanks I'll try poking around in the container later.
Aminorjourney
Aminorjourney
Internet
vehicles that go
To add my voice back into this - sorry -I've been avoiding social media and forums of late because... *things* - I'd note that this integration does now require you to do a little leg work to keep it working.
The GitHub is pretty clear now - https://github.com/itchannel/fordpass-ha - but I would advise if you're anything like me to read it a few times before you try anything, otherwise you will end up scraping your head and screaming.
My system has been working with V 1.70 for literally months now and it's great. I don't have a very frequent refresh interval on purpose, because really what I use this for is remote starting of our Truck on a cold morning or hot afternoon.
We also use it to pipe info to our smart display switches so we can see at a glance how much range each of our EVs have (my bike hasn't got telematics... sad face)
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_7112
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_7110
Ford F-150 Lightning Home Assistant - Ford F150 Lightning Dashboard. IMG_7111
linuxgangster
shane
2023 F150 Lightning xlt
Same with me. I just got my truck and this integration going. I pay more attention to the automation I have built with the Emporia Vue and EVSE along with Solar Assistant. Right now I am refining how I am automating the EVSE to charge my truck based off of my House battey SOC and calculating the excess solar. I wish the Emporia Vue could do what I want but this gives me an excuse to code something. Right now its pretty close to how I want it, I just need to weigh rather or not its worth my time to do it in a more geeky elegant way.
Well based on my file dates, I'm running 1.68 using a token file. It has been working since May 10. But yeah, you should probably use the 1.70 instructions.
zinkscott
Christian
Cloud Engineer
