Future Ford EVs Could Get Charger Success Monitoring System
Ford F-150 Lightning Future Ford EVs Could Get Charger Success Monitoring System 1736358113884-11
Ford Motor Company has filed a patent for a charger success monitoring system that may be used in future Ford EVs, Ford Authority has learned.
The patent was filed on February 16th, 2022, published on January 7th, 2025, and assigned serial number 12187152.
Ford F-150 Lightning Future Ford EVs Could Get Charger Success Monitoring System 1736358158711-hv
Along with launching the “Charge Angels” program that actively seeks out issues with EV chargers in the U.S., Ford has also filed a number of patents recently that aim to make the process of charging an all-electric vehicle easier and more convenient in the future. That list includes ideas for a charging price evaluation system, an EV charger rating system, and a charger reservation system, to name just a few. Now, this newly published patent keeps that trend going with a new idea for a charger success monitoring system that may be used in future Ford EVs, too.
Ford F-150 Lightning Future Ford EVs Could Get Charger Success Monitoring System 1736358186976-uu
As Ford points out in this patent, with the number of EVs on our roads steadily increasing, there are also more and more chargers being built, too. However, these chargers can vary greatly in terms of what type of connectors they offer, as well as charging speeds, availability, reliability, and location, among other factors. As such, it sees a need for a system that would be able to pair EV drivers with the best possible charger near them, which is precisely what we’re looking at here.
Ford F-150 Lightning Future Ford EVs Could Get Charger Success Monitoring System 1736358294564-yb
When it receives a charging request, this proposed system would take into account a vehicle’s attributes and EV chargers along its route to determine the best possible unit, and it would lean on real-time data in many cases. This includes not only advertised charging rates, but also, the rates that customers are actually getting, plus things like charger success rates and availability. From there, the system would recommend a charger to the EV user, and if they agree with that selection, they could simply press a button to navigate there – making for a potentially very useful feature, if it ultimately comes to fruition.
https://fordauthority.com/2025/01/future-ford-evs-could-get-charger-success-monitoring-system/
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Now that they got the patent, bring it on. Subscription I image, but if the cost is minimal it would be great?
On the Road with Ralph
Ralph
Mojave Desert, California
2023 Ford Lightning Pro
Real estate/biz consultant
This is the display I want: Show both the charging rate the vehicle is requesting and what it is actually receiving. In Europe, I think this is required. Electrify America will strenuously object to this because it will rob them of their BS lie that they are simply providing the power requested by the vehicle when they are actually throttling the charger to deal with thermal or other issues. The fact that EA will be against it is all you need to know about it being the right thing to do.
Another needed rule: Gas stations are required by law to post prices so they are clearly visible to passing traffic; charging stations should have to do the same.
PJnc284
Garner, NC
You can get that information with bluetooth obdii dongle and CarScanner app but would be nice to have on the driver's display or center screen. Ford is way behind other manufacturers in information provided. Heck, it took three model years to display charging speed on the IPC. Rivian will tell you if you're charger derated, Porche has a bar to show the optimal temp for charging and believe Mercedes even tells you the max speed you can expect at current SOC/battery temp.
