Stickyleafyo
Josh
23 F150 Lightning Lariat ER
AV Technical Manager
23 Lightning ER Lariat
Eibach 2.9"pro lift
- 2.9" lowest perch set on front
- 0.7" second geo lowest perch on rears
Ready lift SST 3.5 upper control arms
- looks like 23's don't have the headlight sensor? So didn't install the brakes for these.
- got these for better steering geometry, not sure if needed but made me feel better about the angles.
Eibach camber alignment kit made by SPC
Fuel Rebel 6 20x9 +20offset
Nitto Recon grapplers 35x11.50x20
- not too loud but would like to have tired the at4w falkens.
Adjusted speedo using for scan and obdlink + Bluetooth adapter
After lift comments:
- Lost about 15-30% range depending on weather and speed.
- tires are a bit louder but expected with the nature of this vehicle being Soo quiet anyways.
- Road handling much better
Not even a little boaty anymore
- A little bit stiffer but has been breaking in as time has gone on (only 650mi on lift). Betting it's just the stiffer sidewall on the LG rated tires
- There is a baby and I mean tiny amount of rub and half lock turning on the front bottom airdam. It's rubbing it so lightly that you can see only and little hair of rubber lol. So not an issue and will take care of it's self. Could trim in 1mm but why.... ( This could be resolved but using 18mm offset or lower.
Super happy with the results !!
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241223_145341
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241223_172147
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241225_160348
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241221_111052
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241221_141232
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241221_140021
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241225_160332
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241225_160340
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241227_151035
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241227_151044
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241227_151059
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241227_151106
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241227_151116
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241227_151522
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 20241227_151538
AZT9
Peoria, AZ
Did the small lift on the rear help with the terrible camber?
Stickyleafyo
Stickyleafyo
Josh
Yes everything in the rear is now pretty 0. I haven't taken it back in to have them align it after the rear lift. I did the front lift, tires then got it alignment. They did all 4 corners Once I got home from alignment I did the rear lift springs.
Was wondering if I should have them "fix" the alignment in the rear to the factory spec or leave it how it is....
Stickyleafyo
Stickyleafyo
Josh
This is the alignment after the front lift and UCA's and tires / wheels.
I'm assuming after the0.7" lift in the rear it fixed that because I can't see the "squat" anymore and it drives like it's missing rear camber.
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset 1000012855
Andrewbens
Modesto
Lightning
Mechanic
Truck looks great!
AZT9
Peoria, AZ
I understand that the camber is there for a reason but I think the larger tires exacerbates it. I’m looking to add a small lift myself to correct it as there is no actual adjustment for camber in the rear. Only toe
RekaRoyal
Solutions Engineer
It looks really good.
Thanks for the detailed data.
BlueLightning
Thomas
Oklahoma
2023 Ford F150 ⚡XLT SR
Going with 2” spacer for the front, but haven’t installed yet.
Ford F-150 Lightning 23 Lightning ER Lariat Eibach Pro lift 2.9" w/ready lift uppers and nitto 35x11.50r20 fuel rebel 6 +20 offset IMG_1232
Stickyleafyo
Stickyleafyo
Josh
Let me know how the ride quality is after. I find this kit is very stiff compared to stock. Wondering if it's just the tires. Have them at 40psi currently
Andrewbens
Modesto
Lightning
Mechanic
Haven’t noticed any change with my leveling kit besides the truck floats a little more up front.
Stickyleafyo
Stickyleafyo
Josh
Has anyone noticed the very stiff ride compared to stock feeling before the eibach suspension? The little bumps are very bad and seems like offloading has gotten worse. Stock was very comfortable and forgiving off-road where as now I need to air down to 20psi just to be on a dirt road. ..
digitaldad
ABQ
2023 Lariat ER MaxTow
It is stiffer than stock but not that bad/jarring. Make sure the right clip setting was used on the front shocks? Did you upgrade the front upper control arms (UCA)?
Stickyleafyo
Stickyleafyo
Josh
salimbarut
Salim
23 XLT SR
I had the exact same issue with the Eibach setup on my Lightning.
I installed the full front/rear Eibach coilover kit, tried multiple snap ring heights (initially full lift, then OEM springs + lower perch)… and no matter what I did, the ride was unbelievably stiff.
Every small crack, expansion joint, or bump felt like the truck was skipping or jackhammering. I literally couldn’t drink coffee on my commute.
They sell the same kit for ER and SR. I was curious maybe it was because of the weight difference. I contacted the customer support, opened a ticket, and they asked for some photos of measurements. I sent all, but they didn't even respond.
For reference:
  • My previous setup was FOX 2.0 IFP + RC 2” spacer + OEM springs → super comfortable. I thought with the Eibach I may improve that; unfortunately, in my experience, I was wrong.
    Switching to Eibach was night-and-day harsher.
I tested:
  • Different preload settings
  • OEM springs + Eibach struts
  • Lower lift height
  • Wheel spacers on/off
  • Alignment after every change
Nothing fixed the harshness.
Eventually I pulled the entire Eibach setup off the truck and went back to OEM springs + FOX 2.0 + RC leveling spacer.
Now I have ~150 miles used Eibach set that I'm trying to sell, paid lots of money for the labor, many days with Uber while the truck was in the shop, and back to what I had before.
Lessons learned, never ever again.
digitaldad
ABQ
Sorry bud, I missed you were OP here (from your own post) and used the lowest/2.9" setting.
Do you still have your OEM wheels/tires? If so, I would slap them on for a quick check to see if suspension is still as harsh.
