Stickyleafyo
23 Lightning ER Lariat
Eibach 2.9"pro lift
- 2.9" lowest perch set on front
- 0.7" second geo lowest perch on rears
Ready lift SST 3.5 upper control arms
- looks like 23's don't have the headlight sensor? So didn't install the brakes for these.
- got these for better steering geometry, not sure if needed but made me feel better about the angles.
Eibach camber alignment kit made by SPC
Fuel Rebel 6 20x9 +20offset
Nitto Recon grapplers 35x11.50x20
- not too loud but would like to have tired the at4w falkens.
Adjusted speedo using for scan and obdlink + Bluetooth adapter
After lift comments:
- Lost about 15-30% range depending on weather and speed.
- tires are a bit louder but expected with the nature of this vehicle being Soo quiet anyways.
- Road handling much better
Not even a little boaty anymore
- A little bit stiffer but has been breaking in as time has gone on (only 650mi on lift). Betting it's just the stiffer sidewall on the LG rated tires
- There is a baby and I mean tiny amount of rub and half lock turning on the front bottom airdam. It's rubbing it so lightly that you can see only and little hair of rubber lol. So not an issue and will take care of it's self. Could trim in 1mm but why.... ( This could be resolved but using 18mm offset or lower.
Super happy with the results !!
Eibach 2.9"pro lift
