Ford Pass 5.11.0 Android
Same new features as iOS
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738179627746-l5
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738179354999-g2
Today is a nice warm afternoon, figured I would take advantage for a mid-week charging session.
The current charging session statistics are working normally.
I haven't touched the start/stop button on this page, but I'll tickle it near the end of the session.
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738179985038-kd
farmtruck
Pierre SD
22 F350XLT, 2 x 12 F250XLT, 23 Lightning Lariet ER
Farmer
Start/stop should work. I've had 5.11 on the eap program for a week and checked mine when you mentioned it on the IOS thread. I also have not been able to replicate the charge scheduling and reporting issues that the IOS users have mentioned.
I have confirmed that [Stop / Start] is working in the Android 5.11.0 version with today's charging session. After it completed to my set goal, I could restart it, then stop it, then restart, then stop again, from the Energy tab.
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738189433864-6k
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738189452857-a
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738189517552-p8
Thanks for testing this functionality while it was in beta!
farmtruck
Pierre SD
Farmer
It is rather entertaining. I get the android beta about the same time as apple users get the live version. I can then watch the apple comments and check them on my samsung if applicable. Still no widgets for android.
fvineyard
Frank
Roanoke, Virginia, US
2024 F150 Lightning Flash, 2023 IONIQ 5, 2017 CMax
IT Manager
Has anyone noticed that in 5.11.0 for Android we can see the current lock status of the vehicle if you refresh by leaving the main vehicle screen, go the the Energy tab for example, then back to the vehicle screen and for a few seconds it shows locked or unlocked before going back the the default statis of 'Vehicle Parked' ?
As far as I know this is new, but I could have missed this change in a previous version.
Ford F-150 Lightning Ford Pass 5.11.0 Android Screenshot_Unlocked
Ford F-150 Lightning Ford Pass 5.11.0 Android Screenshot_Locked
fvineyard
Frank
IT Manager
Dang, those screenshots are huge. How do I make them smaller when uploading? Is there a thumbnail option?
I tried what you observed, but after doing the lock command then changing tabs, then returning to vehicle tab it continued to show unlocked instead of locked then returning to parked.
Edit post, re upload the parked shot.
Once you load the full sized images you can select each image individually to drag/resize
fvineyard
Frank
IT Manager
I will experiment some more to see if my behavior is consistent. So far I only tried a couple of times. In case it matters have a Pixel 9 Pro XL. Not sure that will matter but it might.
fvineyard
Frank
IT Manager
OK, it only seems to work once after locking or unlocking. If I refresh a second time then it shows the same old Vehicle Parked message. Darn, so close but it might not be intentional.
Sorry for the false alarm :(
farmtruck
Pierre SD
Farmer
Mine just says vehicle parked on that line as well.
fvineyard
Frank
IT Manager
So strange. It works for me once for each of the other tabs. it will report the status twice, as long as I navigate to a different tab each time (Energy and Service). After that it is the same behavior as before. Oh well, I thought I had good news for us :)
davehu
hot springs, AR
Wasn't sure if I should start a new thread on this. Saw that I now have 5.11. This morning with vehicle at 70%, I plugged in (to my FCSP) and got the usual Vehicle will charge to 80% at 6PM. (my target charge settings.) I want to charge now so I hit the start button. It starts a charge session but it states that it will charge to 100%, not 80%. I adjust the slider back to 80% and the session stops completely and says it will charge to 80 after 6PM. there is no way to initiate a charge from the trucks console so my work around is start it, monitor until I reach 80% then hit the stop button. BIG BUG!!!!
