Ford Pass 5.11.0 Android
farmtruck
Pierre SD
22 F350XLT, 2 x 12 F250XLT, 23 Lightning Lariet ER
Farmer
Wasn't sure if I should start a new thread on this. Saw that I now have 5.11. This morning with vehicle at 70%, I plugged in (to my FCSP) and got the usual Vehicle will charge to 80% at 6PM. (my target charge settings.) I want to charge now so I hit the start button. It starts a charge session but it states that it will charge to 100%, not 80%. I adjust the slider back to 80% and the session stops completely and says it will charge to 80 after 6PM. there is no way to initiate a charge from the trucks console so my work around is start it, monitor until I reach 80% then hit the stop button. BIG BUG!!!!
Didn't notice this until you mentioned it. Next time I charge, I will have to check and see if it does the same on mine. I am currently on 5.12beta.
farmtruck
Pierre SD
Farmer
I finally got to check this on mine and you are right. It charges to 100% regardless of scheduled times or maximum charge rates when charging is manually started. Any attempt to adjust max charge while charging will stop charging and change the scheduled charge rate to whatever rate you manually adjusted to.
I will comment to Ford about this when I submit my 5.12 report.
davehu
hot springs, AR
I'm right? gee wish I could get my wife to say that!:):):):)....................thanks
Are you able to manipulate the value here after manually tapping the START charge button?
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738551785069-20
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738552392910-or
After finishing my end of week charging today, I wanted to see what the current session record showed for kWH sent to the battery, so I tapped the START button, that automatically overrules any programmed location based rules (Time & SOC limits), also note the 31.4 kWh is fictitious it stopped accumulating in the last 90 minutes of charging, the Emporia & FCSP insights log as well as the after action charge report in FordPass showed more accurate values.
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738551941558-78
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738552084443-zj
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738552557991-y
Ford F-150 Lightning Ford Pass 5.11.0 Android 1738552224357-l0
farmtruck
Pierre SD
Farmer
Taxmanhog; Yeah I tried using both the charge page and target charge to set the max charge and in both cases, it reset to scheduled at whatever I set the max charge at.
I also see similar erroneous energy numbers. It appears that mine stopped counting about 2 hours into the charge session which was not when I was messing with charge scheduling. I did that in the first half hour. I will have to look at what fordpass reports after the charge cycle completes.
electricpig
Tim
Northwest Arkansas
I believe in my case, it has always functioned this way. Charge now goss to 100%, and has as long as I've had the truck (1 year). Just accepted that this was just the way it was and would set an alarm to remind me when to stop it.
