Did Ford change the motors or throttle response for 2024?
JMD359
One843657295470895!
22 F150 Lightning Lariat,2022 Toyota Rav4 Prime,2011 F350 6.2L
Mechanic
Is this confirmed? Did they put them in an ER lightning yet?
That's 452hp vs the 580hp of the ER. The ER has about 28% more ponies, that would be noticeable.
But it’s carrying what 400 extra lbs between the big battery and mandatory pano roof on the lariats ? It’s going to affect acceleration and the torque is the same
XLT SR is 13.3lbs/hp
Lariat ER is 11.4 lbs/hp
The ER has a 16% edge on lbs/hp. I would notice that I think.
With acceleration from a full stop in an EV (no gears, no motor revving) torque is the quantity that matters and is maximum instantaneously. Once the vehicle gets moving (has motor rpm's) then HP matters. So the ER battery has a greater towing capacity for example because of the higher HPs.
But motor control curves in EVs can change how much torque is used (by controlling applied motor voltage).
Jodokk
Me
NC
22 Lightning Lariat ER, Agate Bl., Max Tow & AT tires. UnderCover Abyss Tonneau
College Professor
Mine is back to normal after a weird night, just after the BC upgrade dropped. No idea what it was....
