My first Tesla supercharger experience.
evowner
Frank
SW Ohio
Retired EE
The reason I charge to 90% is because this is what is the recommended when you are just driving around town, by Tesla and Kia, which is 95% of my journeys. Since the battery on my 2015 Model S can still charge to 100% 10 years later it seemed like it is good advice. I know on a long road trip you might want to charge to 100%. Mine cut off at 90% and I am still figuring out the app. Future long road trips I will change it to 100%.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
I had started to ask about the 90% but never finished the thought. Most of us stop at 80% when DC charging because the charge rate drops off a cliff at 80%. It will hold about 110-120 kW up to 80% and then drop quickly to around 50-60% and continue to taper down. @tommolog did a great video showing the charge curve.
Also, you had stated that you probably had enough range to make it home and you just needed a buffer. We’ve been conditioned by driving ICE vehicles to always fill up when you get fuel. With an EV the mindset should be to just get what you need. When I make my last stop before getting home I get just enough to arrive at home with about 20% charge.
Ford F-150 Lightning My first Tesla supercharger experience. IMG_0310
The reason to not charge to 100% is for battery longevity with charging to 100% (and keeping it there) being relativly hard on the battery and reducing its lifespan. This is why the manufactures recommend only charging to 90%.
However battery degradation at 90% is still quite a bit higher than at 80%, and 80% is higher than 70%, etc.
If you do not need 100% then you should charge to the lowest number(above 50%) that you are comfortable with. Doing so will give you the longest lifespan.
Note, the battery will still charge to 100% if degraded, however the absolute range you can drive will be reduced (note, not the same as what the dash says).
evowner
Frank
SW Ohio
Retired EE
Thanks for all of the help sorting this out. I will try to do best battery care I can.
