Pinero
- First Name
- Jordan
- Feb 2, 2021
- Down the bayou.
- 2021 Lariat Sport 5.0 SCREW FX4
- Occupation
- High Voltage Technician
I’ve used some of the Ruxify solutions on my last truck without issue, so I looked around to see what they make that will work with the 21 f150. Turns out they make a plug and play bed light fixture.
Ruxifey LED F150 bed light
Left: OEM
Right: Ruxifey
INSTALL:
I was already under the truck installing new rear shocks, so I simply reached up to depress the clip from underneath. This was easily reachable.
Use a panel tool to remove the wire harness from the OEM assembly. Unclip the wire harness. Replace with new assembly, and repeat steps in reverse.
I did not take comparison pictures, but the result is a much brighter cool white light. For the $20 price tag, I would definitely recommend these to anyone who works out of the bed a lot.
Left: OEM
Right: Ruxifey
INSTALL:
