✅ 4/18 Lightning Build Week Group
This is a good sign, it means they took it off the internet and put it on the truck.
Mine updated to 5/11.
As did mine, 5/11. I hope that's it loading. Anyone have access to see if they are truly released?
The footer date on the left of center is dynamic [05/11/2022], it represents the generation date of the PDF document, it will change each new day you generate a new PDF view
While the embedded date right of center circled in blue is the blend date [20220420]
The date under the SPECIAL ORDER [04 06 22] is the date the truck was assigned a blend day
Ford F-150 Lightning ✅ 4/18 Lightning Build Week Group 1652306738202
DJBull
2017 Ford F-150 XLT
I don't know if that's correct about the date in the bottom center, there was a point when that date was not updating on a daily basis. I have been saving all of my window stickers and below is an example of one I generated on 5/2 but the date on the bottom center of the sticker was 4/26.
Ford F-150 Lightning ✅ 4/18 Lightning Build Week Group 1652368508575
Ford F-150 Lightning ✅ 4/18 Lightning Build Week Group 1652368547994
Beans
Phil
Beaver Dam, WI
Acura RDX, Toyota 4 Runner
There was a point mine updated every Friday, then lately it updates daily. Someone else on the forum theorized that Ford runs a script that updates all of them. I'm leaning toward that, and that they changed from running it on Friday to running it daily as production ramped up.
OR, the form generation script had a flaw which was fixed recently, I'd guess it is updated on demand, rather than a midnight script.
The oldest earliest builds from 3/15 are still updating as of todays on demand viewing
https://www.windowsticker.forddirect.com/windowsticker.pdf?vin=1FT6W1EV7NWG01414
https://www.windowsticker.forddirect.com/windowsticker.pdf?vin=1FT6W1EV2NWG02616
I looked at my local dealers on site inventory, when I use their link to the sticker it shows a 2021 date https://www.tascafordma.com/api/leg...cguid=SH-18617e86-ec3f-c48a-56f8-be345415e876
When I use the Ford link it shows todays generation date
https://www.windowsticker.forddirect.com/windowsticker.pdf?vin=1FA6P8TD4M5154843
F150ROD
U.S. Navy Retired
I think the form is updated every time there is a change to the form or it is scanned…… or maybe not
blpublic
Missouri
2016 F150 XLT
I was able to start the activation in the FordPass app today. I’ve been trying every few days and was not able to until now. Do we think that means it is close to shipping?
Ford F-150 Lightning ✅ 4/18 Lightning Build Week Group 01231B74-B254-4957-8FFC-A1C096D994E6
Ford F-150 Lightning ✅ 4/18 Lightning Build Week Group 585623B6-A474-4352-A211-F75B03809D6C
Ford F-150 Lightning ✅ 4/18 Lightning Build Week Group 51C5D7B7-3E75-4B88-AEC3-C0492901E4CB
Labs4Lightning
C
I had that almost 2 weeks ago. Doesn’t seem to mean too much.
mine got declined or timed out.
saw another poster that said theirs got accepted. I guess good shuttle driver.
but anyway sit down 🪑 and join the wait 🍻. ⚡
RDeFran
Rich
2020 GMC Sierra 3500HD AT4 SRW Duramax, 2010 M3
Technician
Just tried mine, same thing. Before it just said wait for delivery.
Labs4Lightning
C
Mine still gone. !???
Well the posts to our build week group have declined. I continue to wait for the “blessed event” (non religious) known as delivery to our dealers.
but I assume you can still log onto ford.com and see your reservation under your account? Missing window sticker just causes anxiety - it will come.
Did anyone NOT seeing their sticker based on VIN previously communicated make a A/T to A/S tire change?
F150ROD
U.S. Navy Retired
5/2 build here. I am also not seeing my window sticker since yesterday. At some point I couldn’t log in and it said my VIN didn’t exist. This morning I am able to log in again, but no window sticker. If you used a secondary website you can see the window sticker with the date updated on the bottom with no real changes.
Griddlez
Griddlez
Metro-East of St. Louis, MO
So I found that there is probably just something going on with the Ford-linking tracker. If you go to this site that links to them more directly it should work for you.
https://researchmaniacs.com/VIN-Number-Lookup/WindowSticker/Ford.html
No idea why the above works and not Ford's. My sticker still shows the date at the bottom updating every day even under this alternative site. Must be the real deal sticker - weird the ford site-links don't work.
Dparke55
FL
Lightning Ext, Lightning Std, Mach Ex 4 Rt 1
Manager
Yes I can still log in and see everything. Just says sticker not available when I click the link for sticker. I had access to view since 4/13 I believe, but went unavailable about a week ago now. I just want to see it in front of my house not on my laptop !!
Carminus
Paul
NJ
2022 F150 Lightning Lariat
This link doesn't work for me anymore as it did before. I can still search others though.
Ford Vehicle Order Tracking Home
you will need your vin and 4 digit order number that is on your window sticker.
Example my order number is 4235
Ford F-150 Lightning ✅ 4/18 Lightning Build Week Group 1652629395981
