2025 bricked at 1000 miles {fix post 36}
Thunderand…
Thunderand…
Patrick
2025 Lightning Flash
FireFighter
Thanks for the explanations! I’ll share the work order for sure when I get it.
Henry Ford
The phrase suggests that your vehicle is from an initial production run ("Job-1") and is equipped with a high voltage battery (HVB) that supports an electric motor with a power output of 131 kW (approximately 175.54 hp).
Everyone knows Ford's motto, "Quality is Job 1."
Not many people know the full motto, "Job 2 is Good Enough!"
I’m sorry but that’s all wrong. It’s the energy capacity of the battery that is 131 kWh. You cannot convert kWh to HP.
The combined output of the motors on an ER is 580 HP.
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
Thunderand…
Thunderand…
Patrick
FireFighter
@Thunderand… Has the dealer made any progress on your truck?
Not yet, they’ve done all their diagnostics and said nothing is showing up. They’ve acknowledged the problem and replicated it repeatedly they just don’t know what’s causing it. They’ve called in a ford engineer and a high voltage expert (apparently). I’ve started the buyback process with Ford to get in a new truck.
Thunderand…
Thunderand…
Patrick
FireFighter
Sooooo some good news! Truck should be ready today! Apparently there was a short in the heat pump. Ford engineer spent a week buried in the frunk and found it.
BSEE SPARKY
Derek
Southern Indiana
2023 Lightning Lariat ER, MAX TOW, Power Running Boards
Are you still pursuing a buyback?
Thunderand…
Thunderand…
Patrick
FireFighter
Got my baby back today! Dealer did a great job and was fantastic with communication. I got lots of updates and calls letting me know what was up ended up being the issue they thought. Thank for all the help here.
