285 75 18 Nitto A/T tires on my 2022 Lariat ER
bmw325_num99
Jordan
Chicago, IL
2022 Lightning Lariat ER, 2018 Tesla Model 3
I put these 285/75/18 Nitto tires on some 2018 ICE wheels to get some more ground clearance and a better look. I have a 2" front level kit from Rough Country to make this work.
To be honest, I am not sure it is worth the mileage hit (~25% loss). I might just keep these on for the summer offroading season and go back to my Lightning 18s on stock tires this Fall.
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240407_092054
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240126_145658
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240126_145647
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240402_173655
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240402_173651
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240402_173628
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240402_173634
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240402_173702
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240407_141142
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240402_180916
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240407_141058
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240407_151232
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240407_151210
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 20240404_081408
BlueLightning
Thomas
Oklahoma
2023 Ford F150 ⚡XLT SR
Running those, at -25% loss is always way better than paying $3.79 per gallon for unleaded, LOL! 🤣. Was paying $2.42 at our location but recently went up to $3.05 a gallon. Glad we don’t have to deal with that, go EV!
Adventureboy
The hit probably isn't as bad as it seems. About 8.4% of the apparent range hit is the tire size. You'll cover more ground for every rotation but that won't show on your gauges unless you do a speedo/odometer correction. that probably means you are 15-16% actual range hit primarily from the additional rolling resistance.
Looks good though ;-)
bmw325_num99
bmw325_num99
Jordan
Chicago, IL
Good point. I thought of that a few nights ago but forgot to put it in my post.
I figure with this knowledge, theoretically, the range on my dashboard should deplete at a slower rate than expected right? For example:
The truck thinks I am getting 1.6 mi/kwh. So, it will give me a range of say 200 miles and my destination is 150 miles away. However, due to the rolling diameter error, consumption is actually, say, 1.8 mi/kwh. So as I drive, I would expect to be using less energy than the truck originally estimates and, therefore, again in theory, I would expect to arrive with a bit more range left than the 50 miles originally indicated.
Agreed? I will have to test this out and see if its true.
Adventureboy
I don't have that much faith in the range calculator in NAV and even less faith in the GOM ;-). In theory, it should work that way after the truck adjusts to the new "driving" conditions. In practice, I'm not sure it will but let us know how it does.
I think you can correct the speedo/odometer error using Forescan if you are technically savvy and adventurous. Others might know how to do that. That might cause NAV to give you more accurate numbers.
Effonefiddy Lightning
Alfred
23 F150 Lightning SR Antimatter Blue /2023 Model Y
Just a thought, but, has anyone thought of adding a 2 or 3 inch extension on the active air dam to make up for the increased height. I wonder if a Lightning with just a 2 inch lift and an extension would mitigate the aero loss.:unsure:
bmw325_num99
bmw325_num99
Jordan
Chicago, IL
Interesting idea. Or, for long road trips, one big static airdam like some of the other Fords and the new Tacoma
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 1713189358391-bj
Ford F-150 Lightning 285 75 18 Nitto A/T tires on my 2022 Lariat ER 1713189386880-ie
Ford Motor Company
Official Ford Account
Ford
F-150
Thanks for sharing with us Jordan! And for being a part of the Ford family. :)
