Air Lift Air Bags not available on Powerboost
DT444T
Jake
21 AMB Powerboost Lariat
Meat servo
Probably helped that my F150 was only 4 days from the dealer lot, and 3 months from build date.
Lol that'll help. My truck was probably only a year old and there wasn't any rust but MAN were those two bolts stuck.
Cajin Kevin
Kevin
Central Louisiana
2021 Ford F-150 Lariat FX4 Powerboost
Minister
I have the ride rite by firestone on my PB. No issues with install or availability. I tow a 3 horse trailer and Travel trailer.
Tried to install the Ride Rite system on my '21 F150 Powerboost today. How in the sam hill do you get the mounting brackets in the frame...and then to stay in place while you bolt on the air bag bracket? The mounting brackets kept falling inside the frame. I spent all my time trying to fish them out with a magnet. And yes, I bent the tabs to 45 degrees. I gave up.
itsdchz
Lee
Clovis CA
2021 F150 Powerboost FX4 XLT with Stuff
Did you follow something like the video here:
https://www.etrailer.com/Vehicle-Suspension/Ford/F-150/2021/AL47PD.html
the video is lower left
JPSoup
Jared
Maxatawny, PA
'82 CJ, '18 F150 KR, '22 F150 Platinum (soon)
Sales
Complete install took about 35 minutes. Nothing other than parts and pieces that came with the kit.
THIS is encouraging. I have bags on my '18 KR that I'm hoping to remove and put on the '22 Platinum PB. Sounds like it should move right over and install fine. Only hitch (no pun intended) is that the truck is also ordered with CCD and scales. Can't wait to see the computer have a fit when I put the bags in...
I'm also planning on leveling the truck with 2.5" for aesthetics.
PungoteagueDave
Do you use the air bags at the same time as the WDH?
I do. I started with airbags, but now set everything up with the WDH and then add 25 pounds to the airbags, which makes everything rock solid. It took a lot of tweaking, including $9k to convert my trailer, putting on dual electric-over-hydraulic brakes to accommodate the WDH, all rare for a boat trailer, but required to fit the Ford hitch limit, which tops out at 5K unless using WDH.
hotrodmex
Ca
22 Lariat 500.5a
JPSoup
Jared
Maxatawny, PA
Sales
That's an option! Thank you.
gendibal
M
DMV
Ordered: 2022 F150 Platinum PB
JPSoup
Jared
Maxatawny, PA
Sales
That have an adapter kit for the CCD suspension. I’m instantly interested.
You ordered a similar setup 2 months prior to mine. Keep me posted on what you find/install.
gendibal
M
DMV
Will do. Whenever it arrives…(hoping June)
