Slight "Click" when starting off either in forward or reverse? TSB 25-2044 Post#253
Prime8
Aaron
San Francisco
Colorado
Construction
Hmm, that's not encouraging. I'm on my way to pick up my truck now, it'll be interesting you see if they did the same as others on here.
SO they had my truck for a week. I picked it up and got home yesterday(8 miles) and the click was back! They said they found "loose bolts from the factory" and replaced them and torqued them correctly. The sound is worse today, it's loud enough that pedestrians look over when they hear it..
Ford Motor Company
Official Ford Account
F-150 Lightning
+1 for the clicking.
I hear clicking while accelerating and decelerating around 50 mph
The sound is like when you turn the light switch on and off fast.
Mine is Lariat ER, around 1,000 miles.
Hey there! If you send over a DM with your VIN and Ford dealer info, I can look into your noise concern on my end.
Prime8
Aaron
San Francisco
Colorado
Construction
Unfortunately for Ford, all these little nuances would be ignored on an ICE because of engine noise. Lightning's quiet ride is unable to mask these sounds.
It's quite loud on mine and would be heard over idling engine noise, It's also an unusual sound, it's obviously not normal. The fact that my dealer said it was "loose bolts" after a week of "diagnostics" :) then tightened them only for the sound to remain points to a bigger issue imo...
kWfart
San Diego
2022 Lightning-ER Lariat
Excerpt from a longer version taken with the GoPro clamped to the trailer receiver:
That is exactly how mine sounds! I will check to see if auto hold is on.
drag0n
Kevin
F-150 Lightning Lariat SR
I recently just noticed the clicking on my SR Lariat 800 miles in. Included a video below, is this the same clicking everyone is hearing?
MapleMan650
Santa Cruz Mountains
'22 Ford Lightning Lariat ER, 2017 Ford Mustang GT
I.T.
That’s the click!
data003
Maine
2022 F-150 Lightning Lariat ER
What’s the consensus here, is it worth trying to get it fixed?
data003
Maine
It's worth waiting a bit longer if you are wanting to get it fixed
Yeah fair enough. A stupid dog (not mine) clawed the crap out of my driver’s door so I’m tempted to bring it into the dealer and have them fix both at once.
I'm thinking someone is just giving you a hint that the fix for it isn't quite ready yet, so it is likely worth waiting just a bit until news arrives here that the fix is ready.
Ford Motor Company
F-150 Lightning
BennyTheBeaver
2023 Lightning XLT ER
Well, my truck is being built today. I was hoping this widespread issue would be fixed before my truck was built. Oh well.
lightspeed
2023 Lightning Lariat ER
Has anyone who has the click tried jacking one of the wheels off the ground and moving the tire by hand? If it's the CV joint (or spline), you should be able to replicate the click by twisting the tire by hand (when it's off the ground of course).
Another possibility is the CV mating surface (past the splines) with the wheel hub moving in and out slightly and clicking against the wheel hub. Similar to this:
Some people have said that greasing the splines fixed their click, those splines new are supposed to have tight tolerances, but who knows, maybe the truck's torque is deforming the splines somehow.
So it seems like the options are:
1. CV joint bad or not greased, not likely, usually would make noises when turning
2. splines that are loose in the wheel hub, maybe, they are supposed to be tight, but maybe they are not machined to tight enough tolerances or maybe the torque of the truck is deforming them.
3. axle nut improperly torqued, maybe
4. CV joint 'shoulder' clicking against wheel hub, maybe, especially if axel nut is loose.
